Switched LAN Design
VAbr AVib
I am designing the network backbone for our campus. Attached the diagram for reference.
Before i complete the design phase, please verify this network design and let me know if anybody has any comments.
joelgooding
If you are going to implement these new Cisco devices with the design you have in mind, please contact your Cisco rep to pass you on to a design engineer who will be glad to assist so that Cisco can work with you directly to come up with the best design for your environment and budget.
Looking at your design, are the firewall and router at the network edge single devices? If so it is better to cluster them for redundancy with a firewall cluster and possible an HSRP router configuration sytle. Again it would be best to work with Cisco to solidy the solution and work together to suit your design and budget.
Joel
_______________________________
Please rate helpful posts and answered questions!
Joel _______________________________ Please rate helpful posts and answered questions!
