Switching fails to reach LMS 4.0
mkkhan786
Dear Friends,
i have lms 4.0 problem is that some time our switch are not corresponding with lms ( unresponse event name shows ) ...when i telnet and check switch, switch not ping to lms ip...after i reload, switch communicate properly with lms ...but after two days again issue raise ...picture is attached anyone idea how to start troubleshoot..
Reza Sharifi
When this happens, can the switch reach other resources?
If it can't look at the CPU and memory utilization when it happens.
thanks for reply...
yes switch working properly also reach svi...but not reach this particular lms IP...
lms ip working on 172.16.1.0 network
switches vlan1 ip 10.2.1.0 & 10.1.2.0 networks
intervlan routing correctly configured not other protocol are configured...
CPU and memory utilization normally show....on lms 4.0 .
