Switching STP using vIOS-L2
medharrak
I'm trying to configure STP using vIOS-L2 on GNS3, the loop works only with VLAN1 , for the other VLANs , All the switches display "This bridge is the root"
Any idea about the issue?
7 Replies 7
could be a bug in IOSv2. What exactly do you have configured, what does your topology look like ?
Attached my topology:
4 Switches ,VLANs, VTP (All 4 switches are on Server mode), Trunk between switches , STP.
Hello
Make sure all vlans reside on each switch and are they able to traverse the trunks- Also manually set your primary switch to be the stp root
spanning-tree vlan 1-4094 priority 0
Kind Regards
Paul
VTP works as expected and propagate created VLAN on "DLS1" to all other Switches.
Also I did configure the DLS1 as root primary (spanning-tree vlan 100,200 root primary)
and "DLS2" as backup (spanning-tree 100,200 root secondary ).
hello
and "DLS2" as backup (spanning-tree 100,200 root secondarI posted previoulsy y ).
Specifying the stp root with the root primary/secondary macro won't preempt was if/when an additional switch comes on line with a much preferred bridge id a better way to be more deterministic about stp root placement would use a manual setting as I posted previously also given how flaky CML is it could be the stp root macro isnt work correctly so try/test that command instead.
Kind Regards
Paul
I did change the default encapsulation on Uplinks from ISL to 802.1q and it worked just fine .I don't know why it wasn't working with ISL.
I did change Cisco IOSvL2 to vios_l2-adventerprisek9-m.vmdk.SSA.152-4.0.55.E
and it's working fine.
there is a bug with the version vios_l2-adventerprisek9-m-15.2-2017032.qcow2
