switching T1 on Cisco 8300
rramuk88
I have cisco 8300 router and would like to have two  T1/E1 for redundancy. How do configure the router to switch amongst them in case one of the T1 links fail?
Joseph W. Doherty
If the 8300 is a "router", you should be able to route across both links and allow the "usual" routed path failure techniques to switch between links, as needed.  (Depending on your topology, you may be able to use both your links, to carry traffic, concurrently, too.)
