Bookmark
Subscribe
29071
switchport block unicast/multicast
adamgibs7
Level 6
Level 6
Dears,
I have read about switchport block unicast and switchport block multicast, when these commands are in effect in which situation ???
becz when a switch cam table ages out it has to flood the traffic on each port of the Vlan and the host has to reply so where these command are making sense.
thanks
10 Replies 10
Reza Sharifi
These commands are to block unknown unicast and multicast flooding.
see link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/31sg/configuration/guide/conf/uniflood.html
i have been to this document but I have a confusion that's th reason I post it
these commands are only for private Vlan feature and not for normal Vlan traffic ???
It can work for both private and normal vlans.
but as mentioned in first post, if it is stopping unwanted flooding then when there is no address in cam the table switch default behavior is to flood on all ports.
can u explain me in details
Any body can put shade on the topic above,
Dears,
Anybody can help me for the above query
As you mentioned, the switch default behavior is to flood on all ports, except the port it receives the traffic, when there is no address in CAM table. Unfortunately, if you configure switchport block unicast on an interface, you will not forward the unknown unicast traffic on the port.
One place we use this command is on ports where we connect Access Points. We do not want to forward unknown traffic to any AP where we have more than 50 clients at a time.
HTH,
Meheretab
HTH,
Meheretab
Dear
From you reply what I understand is
switchport block unicast should not be used on the normal end user access ports ?? Please confirm
can u elaborate more on the above paragraph.
The purpose of the command switchport block unicast is to
prevent unknown unicast traffic from being forwarded from
one port to another. If unknown unicast traffic is forwarded, there could be security issues. So, if you are more concerned about security issues, you can configure it on access ports (knowing that those ports will not receive unknown unicast traffic -- I would not do that).
 We prefer not to forward unknown unicast traffic to ports where we plug access points for security reasons.
HTH,
Meheretab
HTH,
Meheretab
Dear
I think there is confusion  between the unknown unicast flooding and bradcasting, can u put some shade on this topic, I m referring many post on the internet but not with solid answers
