Switchport goes up and down
nakama2015
Hi Guys,
My company is using IPT phones model CP-7821
For the past 2 weeks we've been noticing some strange behaviors with certain phones...Once plugged they display "Network Unavailable" and if we take a look into the switch interface and keeps changing from up to down (connected/notconnect). All phones a part of voice VLAN
Strangely, when we connect a regular laptop to the switch-port it works like a charm...we are able to surf the web and use all domain services. We tested different Phones on the same port and the outcome is the same. Switches are POE enabled
#show interfaces fa1/0/17
FastEthernet1/0/17 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 1c1d.8680.8011 (bia 1c1d.8680.8011)
  Description: BTNM
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 1000 bits/sec, 1 packets/sec
     13088 packets input, 1580939 bytes, 0 no buffer
     Received 316 broadcasts (133 multicasts)
     1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 133 multicast, 0 pause input
     27444 packets output, 31395950 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
#show interfaces fa1/0/17 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 2 (BIN:Users)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: 900 (VLAN0900)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: trusted
#show interfaces fa1/0/17 status
Port      Name               Status       Vlan       Duplex  Speed Type
Fa1/0/17  BTNM               notconnect   2            auto   auto 10/100BaseTX
MOZMAP3006#show interfaces fa1/0/17 status
Fa1/0/17  BTNM               connected    2          a-full  a-100 10/100BaseTX
I believe the horizontal cabling is faulty. Since this is a plain 3750, TDR isn't supported.
Better get a reputable cabler to test each links.
6 Replies 6
Seb Rupik
Hi there,
A phone will normally start bouncing its interface when it fails to pick up and IP address so bounces its NIC to restart the DHCP process.
Do your phones have DHCP reservations? Has the IP phone DHCP pool run out of addresses?
cheers,
Seb.
We do have DHCP reservations
The device mac is added under client id for the dhcp pool
Tried plugging the phone directly to the switch and it works...OMG!!!
What could be possible wrong?
Cable replaced. The previous one had a different pin layout
