Switchport only gets an DHCP IP when connect with specific VLAN ID
ralfmusterd
Hi All,
I would like to protect switchports on our switch (used for IP phones) to be used as an internet connection port by our user PC's. Our IP phone can be set with a VLAN-ID (lets say 3) and I would like to configure that only devices that are setup up with VLAN-ID 3 (!) get an DHCP IP on that port. So when and users accidently connects his PC to an outlet port (that is mentioned for IP phone) it does not get an IP by de DHCP because it is on a different VLAN-ID. Is that possible?
Many thanks!
acampbell
If you are using cisco ip phones then tey discover their voip vlan via cdp
So if you configure the switch port like
int f0/1
switchport mode access
switchport access vlan 99
switcport voice vlan 3
Then the phone get a good vlan 3
Any other device using this port would get vlan 99 (no SVI or router interface in this vlan)
If you make vlann 99 UNROUTED then it goes no where.
Alex
Regards, Alex. Please rate useful posts.
Thanks Alex! The phones used are from a different brand (Polycom) :( so I guess this will not work.
Do the Polycom IP phones support VLAN trunking? If so then you could configure something along the lines of the following:
interface <type> <module>/<port>
 switchport mode trunk
 switchport allowed vlan <voice_vlan>
 switcport trunk native vlan <pc_vlan>
 spanning-tree portfast trunk
This should then see the DHCP server give an address on the voice VLAN only to devices that are using IEEE 802.1Q trunking i.e., the IP phone, and an address from another VLAN for those devices not using trunking.
There are a couple of assumptions here
  • The phone supports trunking and it's enabled by default
  • The device an end user connects does not support trunking
