Switchport trunk allowed vlan add statement listed in interface config
Doug Engel
I have a 6509 running 12.2(33)SXI4 that has an interface config that I have never seen before:
interface TenGigabitEthernet3/2
description hv Sw-2-1
switchport
switchport trunk native vlan 308
switchport trunk allowed vlan 1,200,203,206,308,310,318,322,330,340,341,370
switchport trunk allowed vlan add 701
switchport mode trunk
switchport nonegotiate
load-interval 30
spanning-tree bpduguard disable
spanning-tree guard root
end
I have never seen the vlan add statement listed in the interface config.  Why did it not simply add it to the list of allowed vlans?  This is on 4 interfaces that are configured the same.
-Doug
Doug
I wonder when you added vlan 322 to the list whether the switch moved 370 from the first line down to the "add" line? Can you tell us that?
I have seen this behavior (putting some vlan entries onto a vlan add line) on some switches but can not remember whether they were 6500 or not. Like Jon I assumed that it was a limitation on how long a single line can be.
Rick
Rick
11 Replies 11
Jon Marshall
Doug
I wonder if it is just a limitation in terms of the length of a line in the config ie. to add the extra vlan would take the original line past the limit so a new line entry is used.
As long as "sh int trunk" shows all allowed vlans on the trunk i don't think it is an issue.
Jon
I considered that, but I added vlan 322 this morning and it placed it in the list.
701 is shown in the trunk when I do a sh int trunk.
Doug
No idea then unless for some reason it splits up the vlan ranges and needs separate lines for those ranges but i haven't come across this before on 6500s.
Like i say, as long as it on the trunk link i don;t think it matters but it would be interesting to hear if anyone else knows the exact reason.
Jon
Doug
Rick
Rick
That looks like the right answer.  I checked last night's backup and all vlans were in a single list.
Thanks for the suggestion.
ALIAOF_
Level 6
Level 6
If you need to add any more VLAN's to the already allowed list you need to use the add command otherwise you will override what is in there already.
So if you have for example:
And all is working.  Lets say you add another VLAN 701 and want that VLAN added to this list as well.  Now if you do
switchport trunk allowed vlan 701
You will override that list and only 701 will be allowed
So you have to do:
sw trunk allowed vlan add 701
And that is what you are seeing.
Mohammed
Agreed, but that is not the issue here. It is why has the switch used a second line in the config when it could have simply added the vlan to the existing line
Jon
Ah gotcha well in that case what you said above is right.  I believe after like 12 13th one will go on the next line.
Although this is not the issue in this post and it's an older post, I figured I'd post to help someone not run into the issue I've had with a similar problem.
In our environment it shows the switchport trunk allow vlan (number, number,...) and the switchport trunk allowed vlan add (number, number...). I was privy to what Mohammad Ali said about the overwrite, so I copied all the vlans and just inserted the vlan I wanted to add in the list, then I pasted those back in using the switchport trunk allow vlan command (without the add). This put all the vlans I needed back in there...only problem was that it dropped some if not all the vlans that were listed under the switchport trunk allow vlan add section.
With that being said, I'm not sure why it list some in the first line and some in the other, but make sure you use the add command. Like other people have said, even if it's split between the two, as long as you see it one of them it'll be fine.
@darianwhittaker thank you for sharing your experience. There are 2 aspects to this discussion: 1) what is the action of two configuration commands switchport trunk allowed vlan and switchport trunk allowed vlan add 2) the appearance of entries shown in the running config.
I think there is general agreement that the config commands change the content of the running config. The difference in commands is that the command switchport trunk allowed vlan starts with an empty list and adds entries for vlans that will be allowed on this trunk. The command switchport trunk allowed vlan add starts with an existing list of vlans and adds entries to the list.
The confusion is about the appearance of what we see in running config. Most of the time we see only one command switchport trunk allowed vlan and a list of the vlans that are allowed. But sometimes we see both commands with some vlans listed in the first and other vlans listed in the second. The consensus of this discussion is that it reflects a maximum number of vlans that can be listed in the first command. When the list for switchport trunk allowed vlan gets full then it uses switchport trunk vlan allowed add as overflow for additional entries.
Rick
Some of the replies here don't make sense. I've configured 5 650x chassis for over 8 years, adding and changing the "switchport trunk vlan allowed 1,2,3,4,5,6-90, etc hundreds of times. I've always just pasted in the new command with the new or extra vlans in the single command. Same IOS version for years. Never saw that. Until today. Must be 2020 thing.
