''Switchport trunk allowed vlan'' command not blocking vlans.
Oliver42
Hi everybody.
In my network down below I'm trying to block a specific vlan to go through the trunk link between the switch in the orange zone (switchhute) and the switch that it is connected to (2950-1). I want to prevent everybody in the green zone (vlan 22) from getting to the PC called Davicom in the orange zone (vlan 20).
I tried using the command ''switchport trunk allowed vlan 20,21,99'' (99 being the native vlan), but it doesn't work. PCs in the green zone can still ping the Davicom PC in the orange zone through the trunk.
What am I doing wrong? Should I use ACLs instead?
Thank you.
Hello
Yes you should, as denying the vlan on the trunk wont negate connection
your L3 switch:
ip access-list extended no-vlan22
deny ip any 22.22.22.0 0.0.0.255 <-- change for the real address of vlan 22 subnet
permit ip any any
int vlan 20
ip access-group no-vlan22 in
Kind Regards
Paul
Hello
your L3 switch:
permit ip any any
int vlan 20
Kind Regards
Paul
