SWSS or SNTC for Catalyst 9300
swelsch
if i order a 9300 with network essentials, SWSS is included within all dna subscription.
is it possible to download the newest IOS version within the SWSS ? SWSS is desribed as Software support, or do i need the SNTC for IOS updates ?
thanks
Mark Malone
you should be fine with SWSS , as per this doc below explains what you get , SNTC is a little bit extra they go to site etc swap your kit out few other things
Maintenance and minor software releases help reduce risks through bug fixes and security updates, and make sure Cisco software applications are always up to date and perform as expected.
https://www.cisco.com/c/dam/en_us/services/portfolio/documents/support-service-qa.pdf
