T1 MPLS and Broadband backup
Jeff Wolf
          All - I thought I saw a post/question in regards to "how to" configure a Broadband backup for a MPLS circuit..  What I am trying to do is use a cable/dsl/broadband (secondary) connection as a backup to a MPLS circuit (primary).  I have EIGRP and BGP configured on both the branch endpoint and the tunnel headend.  The tunnel is used by the interface that connects to the secondary circuit.  The branch location router is a 1841 and the "headend" tunnel router is a 3825.  I am wondering about the configuration/syntax of a "weight" or static route that can be used to have data flow over the tunnel when the MPLS circuit goes down - and then switch back to the MPLS circuit when it comes back on line..  I can post configs of both the branch endpoint and the tunnel headend as needed..
TIA!!
Jeff
