Tacacs configuration for the Cisco device
Angus Bishop
HI Experts ,
I am having a nexus 7k swich which need to be configured for tacacs
Currently i have cisco routers and switches configured to use the tacacs with the below commands
aaa new-model
aaa authentication login method group tacacs+ local
aaa authentication login local_auth local
aaa authorization config-commands
aaa authorization exec method group tacacs+ local
aaa authorization commands 1 method group tacacs+ local
aaa authorization commands 7 method group tacacs+ local
aaa authorization commands 15 method group tacacs+ local
aaa accounting exec method start-stop group tacacs+
aaa accounting commands 1 method start-stop group tacacs+
aaa accounting commands 7 method start-stop group tacacs+
aaa accounting commands 15 method start-stop group tacacs+
ip tacacs source-interface Vlan100
tacacs-server host 192.168.1.6
tacacs-server host 10.1.22.35
tacacs-server directed-request
tacacs-server key cisco
Can anyone please tell me how to configure the same setup in nexus7k .
Angus
HI Lukee,
Thanks for the reply ,
I neet to know the equialant configuration for the above authorization commands in nexus .
I have configured the nexus and is working , now i need to implement the authorization part .
tacacs-server key 7 "1972"
ip tacacs source-interface Vlan8
tacacs-server host 192.168.1.6 key 7 "1972"
tacacs-server host 10.1.22.35 key 7 "1972"
aaa group server tacacs+ Tacacs
    server 192.168.1.6
    server 10.1.22.35
aaa authentication login default group Tacacs
aaa accounting default group Tacacs
Angus
Hi Angus,
Do the below config in your Nexus switch in order to get autherization.
aaa group server tacacs+ AAA-Server
aaa authentication login default group AAA-Server
feature tacacs+
ip tacacs source-interface Vlan2
tacacs-server host [ip address] key 7 "TEST"
aaa group server tacacs+ TacServer
     server [ip address]
    use-vrf
aaa authentication login default group TacServer
Please rate the helpful posts.
Naidu.
HI All ,
Thanks for all your replies .
I have configured the nexus and added  command attributes under shell profile of ACS and found everything is working fine .
Nexus config
    server 192.168.1.6
    server 10.1.22.35
aaa authorization config-commands default group Tacacs
aaa authorization commands default group Tacacs
ACS CONFIG
Under Policy Element > Authorization and permision > Device administration > Shellprofiles > profilename > custome Attributes > Add entry manual
Attribute : Shell
Requierement : Optional
Value : network-operator  ( Role you requiere )
Angus
