TACACS on HTTP/S - not working?
Greg Dent
Hi all - having difficulty in getting TACACS to authorise logins from HTTP.
I have configured TACACS using the new commands, which has worked fine for CLI logins since day 1. I assumed that in order to enable the same authentication methods for the HTTP server, I would simply have to configure the command "ip http authentication aaa" when configuring the HTTP server. However, this hasnt worked and in fact doesnt allow me to login to the switch at all via the HTTP page, unless I remove that config line, so that it defaults back to enable login.
Here is my TACACS and HTTP config:
aaa new-model
aaa group server tacacs+ llacs
 server name llacs-server
 ip tacacs source-interface Vlan10
aaa authentication login default group llacs local
aaa authentication enable default group llacs enable none
aaa accounting commands 5 default start-stop group llacs
aaa session-id common
tacacs server llacs-server
 address ipv4 1x.x.x.x
 key tacacskey
ip http server
ip http secure-server
When trying to login via the HTTP interface, nothing works, unless I remove the "ip http authentication aaa" line.
How come it works fine for CLI, but doesnt for HTTP? Doesnt make sense!
Any help appreciated.
8 Replies 8
which IOS version are you running ? There is a bug in the older 12.2(58)SE and 12.2.58S, which has been fixed in 15.0(1)SE1.
Either way, is this the full config ? I think you also need the following:
ip http authentication aaa login-authentication default
ip http authentication aaa exec-authorization default
It's an almost brand new switch - running 2960-X version 15.2(2)E6.
I added those commands - thought I may have been missing something. However, they havent helped! Still unable to login with the http authentication configured.
Interestingly, IOS took the command 'ip http authentication aaa login-authentication default' without difficulty, but when issuing the command 'ip http authentication aaa exec-authorization default' it gave the following message:
"Warning: Authorization list "default" is not defined for EXEC."
Not entirely sure what that means!
the commands:
aaa authorization exec default group llacs local
go together. Try and add the 'aaa authorization exec default group llacs local' line first and then the 'ip http authentication aaa exec-authorization default'...
I'm a little confused....
So I have this command already configured:
And then I configured this:
It doesnt work.
Are you saying I need to add them in a different order? That doesnt sound right to me.... AAA/TACACS is working fine for the CLI, so why would it matter what order I add the HTTP commands in?
what do you have configured now, after adding my suggestions ?
That said, are you trying http or https ?
I've tried both HTTP and HTTPS - same issue.
Current config is this:
aaa new-model
 address ipv4 x.x.x.x
 key tacacskey
ip http server
Just realised your post said to config the AAA authorization commands - doh!
I've added that config as below, but still not working :(
something is missing. Can you post the full configuration of the switch ? Also, what is the output of 'show crypto key' ? You might want to zeroize whatever key is in there and create a new one...
