MPLS PE cannot ping CE
Hey guys,
I'm trying to setup an MPLS L3 using GNS3 and C3745E routers.
Everything is up, BGP neighbors are up and running, routes are propaganded.
Problem is, when I try to trace a ping from one end of the customer to the other end, it doesn't work.
I found out that the PE router cannot ping the CE router, but the other way around works.
If I remove:  ip vrf forwarding CUST-A  in the interface and bring back the IP Address, it works, but as soon as I put back the IP vrf forwarding, the ping does not work
Anyone have any idea what I'm missing here?
Thanks!
CE Configuration:
Building configuration...
Current configuration : 1353 bytes
version 12.4
hostname CUSTA-R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip tcp synwait-time 5
interface Loopback0
ip address 5.5.5.5 255.255.255.255
interface Loopback100
ip address 55.55.55.55 255.255.255.255
interface FastEthernet0/0
ip address 15.15.15.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
duplex auto
speed auto
interface FastEthernet2/0
ip address 192.168.3.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet3/0
no ip address
shutdown
duplex auto
speed auto
router bgp 65002
no synchronization
bgp log-neighbor-changes
network 5.5.5.5 mask 255.255.255.255
network 55.55.55.55 mask 255.255.255.255
network 192.168.1.0
network 192.168.3.0
neighbor 15.15.15.1 remote-as 65001
no auto-summary
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
PE Configuration:
Current configuration : 2231 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip cef
ip vrf CUST-A
rd 65002:1
route-target export 65002:1
route-target import 65002:1
no ip domain lookup
mpls label range 1000 1999
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip address 12.12.12.1 255.255.255.0
duplex auto
speed auto
mpls ip
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
ip address 15.15.15.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet4/0
no ip address
shutdown
duplex auto
speed auto
router bgp 65001
neighbor 4.4.4.4 remote-as 65001
neighbor 4.4.4.4 update-source Loopback0
address-family ipv4
neighbor 4.4.4.4 activate
neighbor 4.4.4.4 next-hop-self
no auto-summary
no synchronization
exit-address-family
address-family vpnv4
neighbor 4.4.4.4 send-community extended
exit-address-family
address-family ipv4 vrf CUST-A
neighbor 15.15.15.2 remote-as 65002
neighbor 15.15.15.2 activate
neighbor 15.15.15.2 as-override
no synchronization
exit-address-family
ip route 2.2.2.2 255.255.255.255 12.12.12.2
ip route 4.4.4.4 255.255.255.255 12.12.12.2
ip route 34.34.34.0 255.255.255.0 12.12.12.2
no ip http server
mpls ldp router-id Loopback0 force
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
webvpn context Default_context
ssl authenticate verify all
no inservice
end
11 Replies 11
Julio E. Moisa
The PE will be able to make ping to the CE through the VRF for example
ping vrf CUST-A 15.15.15.2
Now if the ping or traceroute from CE to CE you must verify if the network has added a tag, could you please share your config? At simple sight your configuration looks fine, check the ldp neighbors:
show mpls ldp neighbor
check the forwarding table
show mpls forwarding-table
Also check if CEF is enabled.
show ip cef.
Thank you
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
R1#show mpls forwarding-table
Local Outgoing Prefix Bytes tag Outgoing Next Hop
tag tag or VC or Tunnel Id switched interface
1000 Pop tag 2.2.2.2/32 0 Fa0/0 12.12.12.2
1001 2002 4.4.4.4/32 0 Fa0/0 12.12.12.2
1002 2003 34.34.34.0/24 0 Fa0/0 12.12.12.2
1003 Untagged 5.5.5.5/32[V] 0 Fa0/1 15.15.15.2
1004 Untagged 55.55.55.55/32[V] 0 Fa0/1 15.15.15.2
1005 Untagged 192.168.1.0/24[V] 0 Fa0/1 15.15.15.2
1006 Untagged 192.168.3.0/24[V] 0 Fa0/1 15.15.15.2
But there seems to be a problem with the other side:
When I try to add the vrf inside BGP, it accepts the commands but its not shwing into the run config
neighbor 46.46.46.6 remote-as 65002
neighbor 46.46.46.6 activate
neighbor 46.46.46.6 as-override
no synchronization
exit-address-family
R4#show mpls forwarding-table
4000 3000 1.1.1.1/32 0 Fa0/0 34.34.34.1
4001 Pop tag 3.3.3.3/32 0 Fa0/0 34.34.34.1
4002 3003 12.12.12.0/24 0 Fa0/0 34.34.34.1
Here's the config
Current configuration : 2043 bytes
version 12.4
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip cef
ip vrf CUST-A
no ip domain lookup
mpls label range 4000 4999
interface Loopback0
ip address 4.4.4.4 255.255.255.255
ip address 34.34.34.2 255.255.255.0
duplex auto
speed auto
mpls ip
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip address 46.46.46.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 65001
neighbor 1.1.1.1 remote-as 65001
neighbor 1.1.1.1 update-source Loopback0
address-family ipv4
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 next-hop-self
no auto-summary
no synchronization
exit-address-family
neighbor 1.1.1.1 send-community extended
exit-address-family
ip route 1.1.1.1 255.255.255.255 34.34.34.1
ip route 3.3.3.3 255.255.255.255 34.34.34.1
ip route 12.12.12.0 255.255.255.0 34.34.34.1
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
no inservice
end
You have not configured any address family with VRF on R4.
Also LDP protocol is not running on the routers, you need to configure OSPF on the PE to interconnect with the P routers, for example I sugget remove static routing and use OSPF or ISIS
Example:
CE-Router1  ------ PE-Router2 ------ P-Router3------ PE-router4 -------CE-router5
CE-Router 1
interface loopback 0
interface loopbak 1
ip address 11.11.11.1 255.255.255.0
interface fa0/0
description TO-PE-ROUTER-2
no shutdown
router bgp 100
no sync
no au
neighbor 15.15.15.1 remote 777
network 1.1.1.1 mask 255.255.255.255
network 11.11.11.0 mask 255.255.255.0
PE-Router-2
ip vrf CUST-A
rd 65002:1
ip address 2.2.2.2 255.255.255.255
mpls ldp router-id loopback 0
interface fa0/0
description TO-CE-ROUTER-1
ip vrf forward CUST-A
no shutdown
interface fa0/1
description TO-P-ROUTER-3
ip address 10.23.0.2 255.255.255.0
no shutdown
router ospf 100
mpls ldp auto
network 2.2.2.2 0.0.0.0 area 0
network 10.23.0.2 0.0.0.255 area 0
router bgp 777
no sync
no au
neighbor 4.4.4.4 remote 777
neighbor 4.4.4.4 update-source loopback0
address-family vrf CUST-A
neighbor 15.15.15.2 remote 100
neighbor 15.15.15.2 as-overide (If the other CE is using AS 100 as well)
P-Router 3
ip address 3.3.3.3 255.255.255.255
interface fa0/1
description TO-PE-ROUTER2
ip address 10.23.0.3 255.255.255.0
no shutdown
interface fa0/0
description TO-PE-ROUTER4
ip address 10.34.0.3 255.255.255.0
no shutdown
router ospf 100
mpls ldp auto
network 3.3.3.3 0.0.0.0 area 0
network 10.23.0.3 0.0.0.255 area 0
network 10.34.0.3 0.0.0.255 area 0
Now PE-router4 and CE-router5 must similar to CE-router1 and PE-router2 with specific addressing.
Hope it is useful
Here's the config of my P routers
I agree I should use something more dyunamic but MPLS is still configured in them
If I use OSPF , should I remove MPLS IP in the interface?
R2#show run
Current configuration : 1619 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip cef
no ip domain lookup
mpls label range 2000 2999
interface Loopback0
ip address 12.12.12.2 255.255.255.0
duplex auto
speed auto
mpls ip
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip address 23.23.23.1 255.255.255.0
duplex auto
speed auto
mpls ip
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip route 1.1.1.1 255.255.255.255 12.12.12.1
ip route 3.3.3.3 255.255.255.255 23.23.23.2
ip route 4.4.4.4 255.255.255.255 23.23.23.2
ip route 34.34.34.0 255.255.255.0 23.23.23.2
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
no inservice
end
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip cef
no ip domain lookup
mpls label range 3000 3999
interface Loopback0
ip address 23.23.23.2 255.255.255.0
duplex auto
speed auto
mpls ip
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip address 34.34.34.1 255.255.255.0
duplex auto
speed auto
mpls ip
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip route 1.1.1.1 255.255.255.255 23.23.23.1
ip route 2.2.2.2 255.255.255.255 23.23.23.1
ip route 4.4.4.4 255.255.255.255 34.34.34.2
ip route 12.12.12.0 255.255.255.0 23.23.23.1
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
no inservice
end
The inconvenience is that LDP protocol is not being enabled on the PE and P routers, you need this protocol to enable the tagging. Please provide me your topology with the addressing in order to provide the configuration.
Also the suggestion is use OSPF or ISIS into the Service Provider Infraestructure to deliver MPLS services. So the static routing should be removed.
Thanks for helping me out!
Here's where I actually took this exemple:
http://resources.intenseschool.com/gns3-lab-introduction-to-mpls-layer-3-vpn-part-1/
Topology
CE ---(PE)R1-Fa0/0 --- Fa0/0- R2 -fa0/1  -----  fa0/0-R3- fa0/1 ------  fa0/0- R4 (PE) -Fa0/1 --- CE
R1::
interface Loopback0
interface FastEthernet0/0  (to R2)
R2::
interface Loopback0
interface FastEthernet0/0 (to R1)
mpls ip
interface FastEthernet0/1 (to R3)
R3::
interface Loopback0
mpls ip
interface FastEthernet0/1 (to R4)
R4::
interface Loopback0
interface FastEthernet0/0 (to R3)
mpls ip
Thank you Jean,
Im going to work on this and share the configuration.
Bonjour Jean-François,
In addition to the things Julio pointed out, you are also missing a route distinguisher (RD) under vrf CUST-A on the PE R4.
no synchronization
exit-address-family
Here's the config
version 12.4
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip cef
ip vrf CUST-A
no ip domain lookup
interface Loopback0
duplex auto
speed auto
mpls ip
interface Serial0/0
no ip address
shutdown
clock rate 2000000
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 65001
address-family ipv4
no auto-summary
no synchronization
exit-address-family
exit-address-family
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
no inservice
end
Your config should be like:
CE-Router 1
interface loopbak 1
interface fa0/0
no shutdown
router bgp 100
no sync
no au
PE-Router-2
ip vrf CUST-A
rd 65002:1
interface fa0/0
no shutdown
interface fa0/1
no shutdown
router ospf 100
mpls ldp auto
router bgp 777
no sync
no au
P-Router 3
interface fa0/1
no shutdown
interface fa0/0
no shutdown
router ospf 100
mpls ldp auto
Hope it is useful
Jean-François,
You are still missing the RD under the VRF config.
ip vrf CUST-A
rd xxx:xxx
