TCP connection question
Sergey Tregubov
I have a question about establishing a tcp connection
We have a web server,so a tcp request will go via plain ethernet connection, without encryption, but all traffic from the web server subnet is encrypted, without exception.
Will it work or not? Can tcp establish connection in that way?
Thank you
Ganesh Hariharan
Thank you
If user access the web server on https request and encryption is enable on webser to decrypt the https request it wont affect the tcp transction,as tcp packet will be handled with https as L7 header.
Hope to Help !!
Ganesh.H
