telnet probleme
shadaabahmed
Community Member
dear
AS i am having datacenter switch (6500) from my local pc i cant telnet to switch
but from diffrent switch i can telnet the datacenter switch .
i can ping from my pc to that particular ip its pinging
and before to say that we are having complte layer 3 secnario
i am thinking that is there any looping issue.
but not when i try to telnet from my other employ pc telnet is working fine
have any person came to the issue
and plz note its not the access-list probleme
wdrootz
Level 9
Level 9
1) You have mentioned that the 'ping' from your PC to datacenter switch works, so there can't be any loops.
2) You are able to telnet the datacenter switch from a different switch and also from a different PC, so the issue could be with your PC.
Could you try pinging from your PC to a different device in same subnet as that of the datacenter switch. You can try with the 'tracert' command to find out where the packet gets dropped.
Also try to search in Cisco.com website with the error message you get while trying to telnet to the datacenter switch. This would get the appropriate solution.
