term monitor command
jjoseph01
Level 3
Level 3
Hi all. Im trying to monitor a router remotely by doing some debug commands. I executed the "term mon" command, so that the debugging would show up, but I dont get anything on the screen. Ive verified that debugging is on (show debug), and I should be seeing something. However, nothing shows on the screen. Anyone seen this before or know what the resolution is?
jjoseph01
Level 3
Level 3
got it all. thanks. the no logging console was on. Its fixed now. Thanks.
don't you mean you enabled ?
