TFTP Interface
Dear all,
is it possible to "say" a multilayer swtich (3750) which interface he should use for a tftp upload? With ping and trace I can, but is it for tftp for example also possible?
It would be helpfull for our firewall configuration on remote locations.
Thanks in advance
Sebastian
2 Accepted Solutions
Giuseppe Larosa
Hello Sebastian,
the interface on the path to destination is chosen normally.
to have a consistent behaviour you should use something like
ip tftp source-interface vlan10
in global config
Hope to help
Giuseppe
dario.didio
Level 4
Level 4
yes you can specify this by using following command using lo0:
ip tftp source-interface Loopback0
HTH,
Dario
5 Replies 5
Giuseppe Larosa
Hello Sebastian,
in global config
Hope to help
Giuseppe
dario.didio
Level 4
Level 4
HTH,
Dario
Hey Guiseppe, Dario,
Thanks a lot for the fast replies, very easy and I didn't find it in the conf guide...
Best regards,
Sebastian
Great Dario....Thank's..
