TFTP Method for SHOW IP INT B
mramirez-t
So I ran sho ip int br on a switch and saw TFTP set up for:
Vlan1 unassigned YES unset up up
Vlan1000 10.2.0.10 YES TFTP up up
FastEthernet0 unassigned YES TFTP down down
None of the other interfaces says TFTP, but this is the first time I encountered this.  And what I can find, that means this switch receives its startup-config from a TFTP server, which isn't true.  I need to reboot the switch and since this is remote (4 states away), I'm a little concerned its going to try loading some startup-config from some TFTP server somewhere and the switch isn't going to reboot normally.  Not really a concern of mine if the switch is right down the hall, but since its so far away, need a little advice please.
Running-config:
DC-02#show run
Building configuration...
Current configuration : 32392 bytes
! Last configuration change at 02:12:12 UTC Sat Mar 18 2017
version 15.2
parser config cache interface
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname XXXX
boot-start-marker
boot-end-marker
logging buffered 256000
no logging console
logging monitor critical
username corebts privilege 15 secret 5 $1$hCuY$3qYPtATZ/P0EhwhNlr/.D1
username admin privilege 15 secret 5 $1$USFm$GIFJsQ0ak0x.kBIrm6zj9/
aaa new-model
aaa group server radius XXXRadius
server-private 10.11.144.114 key 7 10715D1C1C333B292D3C76
aaa authentication login default group XXXRadius local enable
aaa authorization console
aaa authorization exec default group XXXRadius local
aaa session-id common
switch 1 provision ws-c2960x-24pd-l
switch 2 provision ws-c2960x-24pd-l
switch 3 provision ws-c2960x-24pd-l
no ip source-route
no ip domain-lookup
ip domain-name XXX.org
login block-for 120 attempts 5 within 60
login on-failure log
login on-success log
vtp domain XXX
vtp mode transparent
mls qos map policed-dscp 0 10 18 24 46 to 8
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
crypto pki trustpoint TP-self-signed-3575411584
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3575411584
revocation-check none
rsakeypair TP-self-signed-3575411584
crypto pki certificate chain TP-self-signed-3575411584
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33353735 34313135 3834301E 170D3136 31323037 32303236
32345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 35373534
31313538 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100AB9C 3B2E4540 90386A8D 99702C57 F1A84BDD 92A1B57B 811EB3A1 FB4D0E94
16BD9C79 8AB5D316 25456F06 0142239C 649398E2 4DD4BE2F 11A3028D 76BF4A0A
76D464BC 1EF66B39 AA8DABC6 05410964 CA887B2F 00921AC0 6E49DEF5 422973CE
4635B510 3A6B72DA 1747F205 CA677597 F5A9450D E660024E B283701D 4C62AF37
A1F10203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 145C5072 E3E6ABCC 2358B58D 6D2BDF86 E50FBD7C 76301D06
03551D0E 04160414 5C5072E3 E6ABCC23 58B58D6D 2BDF86E5 0FBD7C76 300D0609
2A864886 F70D0101 05050003 81810079 40561025 71880E0A 33728032 1628ADED
3303048C 53FD4F6A 739F4E24 A8F80EB9 6A5CC5DD DF4EB6F1 22252F49 EC332A32
D39066EA 1A123816 6692C439 6DB9D9EF CC3029C9 1F973130 F6CB0683 B6D32236
D91D2A2D 8918FBDD A11221C4 05069A82 2832F50E CB155B28 0A912C7F BD83A8D2
B6310BA3 7F594979 E8064A96 8B448E
quit
archive
log config
logging enable
logging size 1000
notify syslog contenttype plaintext
hidekeys
path flash:BackupConfig
maximum 7
write-memory
spanning-tree mode rapid-pvst
spanning-tree portfast bpduguard default
auto qos srnd4
vlan internal allocation policy ascending
vlan 35
name XXXX-METRO-LAN
vlan 100
name XX-DATA
vlan 150
name XX-VOICE
vlan 1000
name MGMT
ip tcp synwait-time 5
class-map match-all AUTOQOS_VOIP_DATA_CLASS
match ip dscp ef
class-map match-all AUTOQOS_DEFAULT_CLASS
match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
match ip dscp cs3
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
class AUTOQOS_VOIP_DATA_CLASS
set dscp ef
police 128000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_VOIP_SIGNAL_CLASS
set dscp cs3
police 32000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_DEFAULT_CLASS
set dscp default
police 10000000 8000 exceed-action policed-dscp-transmit
interface Null0
no ip unreachables
interface Port-channel24
description Uplink to Core Switch
switchport mode trunk
interface FastEthernet0
no ip address
interface GigabitEthernet1/0/1
switchport access vlan 100
switchport mode access
switchport voice vlan 150
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
interface GigabitEthernet1/0/2
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/3
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/4
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/5
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/6
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/7
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/8
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/9
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/10
description WDC-AP1
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/11
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/12
shutdown
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/13
description WDC-ADS01
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/14
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/15
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/16
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/17
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/18
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/19
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/20
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/21
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/22
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/23
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/24
priority-queue out
mls qos trust cos
interface GigabitEthernet1/0/25
description Zayo Metro LAN
switchport access vlan 35
interface GigabitEthernet1/0/26
switchport trunk native vlan 100
priority-queue out
mls qos trust cos
auto qos trust
interface TenGigabitEthernet1/0/1
priority-queue out
mls qos trust cos
auto qos trust
channel-group 24 mode active
interface TenGigabitEthernet1/0/2
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust dscp
auto qos trust
interface GigabitEthernet2/0/1
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/2
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/3
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/4
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/5
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/6
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/7
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/8
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/9
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/10
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/11
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/12
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/13
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/14
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/15
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/16
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/17
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/18
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/19
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/20
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/21
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/22
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/23
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/24
priority-queue out
mls qos trust cos
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface TenGigabitEthernet2/0/1
interface TenGigabitEthernet2/0/2
interface GigabitEthernet3/0/1
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/2
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/3
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/4
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/5
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/6
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/7
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/8
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/9
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/10
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/11
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/12
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/13
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/14
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/15
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/16
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/17
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/18
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/19
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/20
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/21
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/22
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/23
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/24
priority-queue out
mls qos trust cos
interface GigabitEthernet3/0/25
interface GigabitEthernet3/0/26
interface TenGigabitEthernet3/0/1
interface TenGigabitEthernet3/0/2
interface Vlan1
no ip address
interface Vlan1000
ip address 10.2.0.10 255.255.255.0
ip default-gateway 10.2.0.1
no ip http server
no ip http secure-server
ip ssh time-out 29
ip ssh authentication-retries 2
ip ssh logging events
ip ssh version 2
ip access-list extended AUTOQOS-ACL-DEFAULT
permit ip any any
logging trap debugging
snmp-server community XXXXXXX RO
radius-server timeout 2
line con 0
exec-timeout 30 0
privilege level 15
logging synchronous
line vty 0 4
exec-timeout 30 0
privilege level 15
logging synchronous
transport preferred ssh
transport input ssh
line vty 5 15
exec-timeout 30 0
privilege level 15
logging synchronous
transport input ssh
end
Reza Sharifi
I personally would not risk rebooting a stack of switches that is 4 states away just because one of its interfaces is configured to get its info from tftp. I would do it in the feature when you need to reboot them for a more critical reason.
Thanks for the suggestion about not rebooting it remotely, but getting, quite frankly, obvious advice on the pitfalls of remote rebooting wasn't the reason for my post.
I found out how to fix it anyway and got it to not be TFTP and was able to remote reboot with no problem.
I am in exactly same dilema, can you send me pricedure on how toi fix it.
"sh ip int br" shows MGMT vlan interface as "TFTP". Also it is preventing me from remote access to the swicth Stack (although console works).
Do I need to reboot the whole stack after applying the fix?
kazmia@yahoo.com
