TFTP with timestamp
sunriderhk
We got C2960 switch. May I know how to use kron autobackup by using TFTP with timestamp?
Hugo
9 Replies 9
Leo Laohoo
archive
 log config
  logging enable
  hidekeys
 path tftp://<TFTP IP address>/$h-
 write-memory
 time-period 10080
The command above saves the configuration to the TFTP in two ways:
1.  When one saves the config; and
2.  Every 7 days.
In the TFTP, the file will be saved with time and date stamp as part of the filename.
How to change the timestamp format, I got error as follow?
2960G#sh archive
The next archive file will be named tftp://192.168.1.1/2960G-Feb-24-10:33:34-cfg-1
 Archive #  Name
   1       :Error - Bad file number
Timestamp config:
service timestamps debug datetime localtime
service timestamps log datetime localtime
config t
serv time d d s l y
serv time l d s l y
end
Try that.
same , fail
same , fail
Wait ... where are you looking at this?  You should be looking for the file(s) in your TFTP server and not in the switch.
i cannot find backup config in tftp server as well
Save the config of the switch and see what happens to the prompt.
Check if you have a FW stopping TFTP from going through.
acampbell
Have a look at this link
http://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-releases-122-mainline/46741-backup-config.html
Alex
Regards, Alex. Please rate useful posts.
Johannes Botha
@sunriderhk
Another way to get daily backup is to use kron
archive
 path tftp://IP_of_TFTP_SERVER/$h__$t
 write-memory
kron occurrence daily-config-backup at 0:05 recurring
 policy-list backup-config
kron policy-list backup-config
 cli write memory
Make sure you switch or router time is synced
