The best solution for IPTV
John Hill
Recently we bought HDMI QAM modulator, it has iptv output as well. So we are looking for robust business-grade solution to distribute IPTV sream among out office building ( ~50 PCs). IPTV stream is RTP MPTS multicast signal. We would prefer the easiest solution to set up.
Thank you!
Best Regards,
John Hill
Reza Sharifi
Hi John,
If the device has an Ethernet output, you can connect that to your switching environment and run multicast for your IPTV channels. Also, use the management port (if it has one) to connect to the device.
