The difference b/w physical removal & entering shutdown command?
     Hi all,
         What is the difference between A port has enabled by no-shutdown command but it has not physically connected and for the same port has been disabled by shutdown command even it has physically connected with other device?
           Thanqs in advance.
Ganesh Hariharan
     Hi all,
           Thanqs in advance.
The no shutdown command. An interface may be correctly configured and physically connected, yet be "administratively down." In this state it will not function at all.Operational enable state only has something to do with the type of port.
Either access or trunk or none/disable.
Access Ports for clientpc will be (#switchport mode access) and  trunk for uplink to another switch or router(#switchport mode trunk)
This is the output from #show interface
Port is shutdown:
FastEthernet0/1 is administratively down, line protocol is down (disabled)
Port is no shutdown and is not connected
FastEthernet0/2 is down, line protocol is down (notconnect)
Port is no shutdown and is connected
FastEthernet0/3 is up, line protocol is up (connected)
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Tharak Abraham
Level 3
Level 3
Routing impact wise, there wont be any difference in convergence.
But the status of the both will be different as told in the other thread by Ganesh.
Similarly, doing a no-shut on an interface which is not connected doesnt make any difference other than in the interface status.
btw If you are trying to do some advanced testing for Autoneg or Convergence, do let know the scenario.
