the difference between system priority and bridge ID?
Cossak Yu
I am reading the CCNP self Study BCMSN Official Exam Certificate Guide Fourth Edition. There is a System priority in the LACP set up. That is 2 bytes for priority value followed by a 6 byte MAC address. I am wondering what is the difference between system priority and the bridge ID related to STP. Bridge ID also consists of 2 bytes bridge priority and 6 bytes MAC address. if they are the same, why they are given two different names? Could any one give me a help on this?
thanks,
Cossak
Viral Bhutta
LACP system Priority is the combination of the LACP system priority value and the MAC address of the switch.
You can configure it using lacp system-priority priority_value
LACP uses the system priority with the switch MAC address to form the system ID and also during negotiation with other systems.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/channel.html#wp1033345
Each VLAN on each network device has a unique 64-bit bridge ID consisting of a bridge priority value, an extended system ID, and an STP MAC address allocation.
Configuring Bridge ID Priority
spanning-tree vlan vlan_id priority bridge_priority
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/spantree.html#wp1096536
In short, both values are different.Both are used for different purpose.
Hope this helps.
