The Flash memory doesn't initialized
erickrod54
Community Member
I need help please who could would help me i'll apreciate:
the problem shows an error in a switch catalyst 2900XL - its a 2924 -, i was copying the image of the ios via xmodem and before finished the the power energy in the facility shuts down,  when the energy supply returns the switch get power energy normally but the flash memory doesn't initialized and the loader stuck when i try to initializy the flash or reset and i don't know what to do a wish that someone help me with that please
my contact mail is erickrod54@gmail.com
this is the error that shows me:
switch: flash_init
Initializing Flash...
flashfs[0]: 21 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4499456
flashfs[0]: Bytes available: 3241984
flashfs[0]: flashfs fsck took 7 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
....and then stuck the loader.
Hi Erick,
I don't think there is any guide.
Just make sure you have anti-static strap on.  The flash memory is like a PC DRAM memory.
8 Replies 8
Leo Laohoo
Flash is fried.
oh nooooo... but before that the switch works fine, and there something i can do to fix it?
If you have another 2900XL lying around, you can swap parts around.
i will check if i find some parts of another switch 2900XL, Is there a guide to change it?.. I'm ccna but i'm afraid to change it without support :S
Hi Erick,
thank you leolaohoo i'll do with carefully to change it.. how i vote for you ?
Hi Erick,
Sorry.  I'm can't/not allowed run for public office.
Thanks for the ratings.
that's ok xD... but maybe you will be the next president of cisco jeje xD, thanks for your assistance
