The interface 'Gi1/0/4' is checked for outbound discarded packets.
jain.manish94
 Suppose The interface 'gi1/0/4' is checked for outbound discarded packets.
Please can you tell me what to do , i am facing this problem on interface gi1/0/4(core switch L3 Cisco 3850, cisco WS-C3850-24S) which is connected to Router.
Description: The number of discarded outbound packets on 'Gi1/0/4' (101 Pkts/s,0.00% last 15 min.) is exceeding the threshold (10 Pkts/s).
Please can you tell me the process point by point.  what i check and how to resolve...
Manish
jain.manish94@gmail.com
23 Replies 23
Leo Laohoo
What is the IOS version?
Post the complete output to the command "sh interface Gi1/0/4".
sh interfaces gigabitEthernet 1/0/4
GigabitEthernet1/0/4 is up, line protocol is up (connected)
Description: RTR_1**
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:34, output never, output hang never
Last clearing of "show interface" counters 3d21h
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 876938
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 149000 bits/sec, 114 packets/sec
5 minute output rate 186000 bits/sec, 130 packets/sec
69065573 packets input, 23721635297 bytes, 0 no buffer
Received 501623 broadcasts (501623 multicasts)
0 watchdog, 501623 multicast, 39585 pause input
66735477 packets output, 17582039282 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
sh interfaces gigabitEthernet 1/0/4 stats
Switching path           Pkts In            Chars In           Pkts Out           Chars Out
Processor                   6238               2432820             0                            0
Route cache               0                     0                    691747               46822276
Total                          6238               2432820           691747              46822276
This is a pretty high value for a 3-day counter.
I'd recommend QoS needs to be enabled on the interface or traffic-shapping policy be enabled on the router interface (facing the switch).
please can you tell me which value is high . where did you find error. please let me know.
The most common reason why the high output drops is when a high-speed appliance, like a SAN server (for example), is connected to a Cisco Catalyst switches.
Cisco Catalyst switches (not Nexus) is well known for shallow buffer, as designed.  For high-speed and hit-less application, Cisco always recommend the Nexus family of switches.
Otherwise, QoS will need to be configured on the switch and/or policy-shaping configured on the router.
Thanks you very much for you reply and give solution but please tell me the commands to configure Qos or enable policy-shaping configured on the router.....
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It's possible your device has a very bad config, that drops packets prematurely, but more likely is some source, or sources, of traffic that's just more than the gig interface can handle.
Leo's example of a SAN device is good, but it could also be the combination of traffic from multiple devices, whose aggregate is too much for the gig interface.
What are the usual solutions?
Well, if the congestion is from transient bursts, and queuing delay isn't another issue, increasing interface queuing capacity might be one solution.  This might require another "better" device, or sometimes, reconfiguration of the device.
If the congestion is sustained, either you need to provide more bandwidth (e.g. Etherchannel or 10g to the router) or, if device supports, you need to better manage traffic flow rates.  The latter can be done in various ways, all not mutually exclusive, but all usually very dependent on device capabilities and protocols being used by traffic.  For example, TCP will slow its transmission rate when it detects packet drops, so QoS might manage when and what packets to drop to minimize overall packet drops, yet maximizes transmission rate.
Hello Joseph
Please i want to know that.
1. before it was working but now i have to do manually take all backup from NCM solar winds of my all device one by one.
Please can you tell me what i check to solve this problem
please someone can tell me. meaning
sh controllers ethernet-controller gigabitEthernet 2/0/24
Transmit GigabitEthernet2/0/24 Receive
24793314955 Total bytes 149735195722 Total bytes
117430828 Unicast frames 153158983 Unicast frames
24440809649 Unicast bytes 149581487325 Unicast bytes
4693655 Multicast frames 2083514 Multicast frames
343851894 Multicast bytes 153705677 Multicast bytes
121064 Broadcast frames 40 Broadcast frames
8653412 Broadcast bytes 2720 Broadcast bytes
0 System FCS error frames 0 IpgViolation frames
0 MacUnderrun frames 0 MacOverrun frames
0 Pause frames 501 Pause frames
0 Cos 0 Pause frames 0 Cos 0 Pause frames
0 Cos 1 Pause frames 0 Cos 1 Pause frames
0 Cos 2 Pause frames 0 Cos 2 Pause frames
0 Cos 3 Pause frames 0 Cos 3 Pause frames
0 Cos 4 Pause frames 0 Cos 4 Pause frames
0 Cos 5 Pause frames 0 Cos 5 Pause frames
0 Cos 6 Pause frames 0 Cos 6 Pause frames
0 Cos 7 Pause frames 0 Cos 7 Pause frames
0 Oam frames 0 OamProcessed frames
0 Oam frames 0 OamDropped frames
196590 Minimum size frames 18773829 Minimum size frames
98198093 65 to 127 byte frames 11186373 65 to 127 byte frames
7258031 128 to 255 byte frames 13052114 128 to 255 byte frames
3776169 256 to 511 byte frames 3528987 256 to 511 byte frames
3020499 512 to 1023 byte frames 3039011 512 to 1023 byte frames
9796165 1024 to 1518 byte frames 105662708 1024 to 1518 byte frames
0 1519 to 2047 byte frames 16 1519 to 2047 byte frames
0 2048 to 4095 byte frames 0 2048 to 4095 byte frames
0 4096 to 8191 byte frames 0 4096 to 8191 byte frames
0 8192 to 16383 byte frames 0 8192 to 16383 byte frames
0 16384 to 32767 byte frame 0 16384 to 32767 byte frame
0 > 32768 byte frames 0 > 32768 byte frames
0 Late collision frames 0 SymbolErr frames
0 Excess Defer frames 0 Collision fragments
0 Good (1 coll) frames 0 ValidUnderSize frames
0 Good (>1 coll) frames 0 InvalidOverSize frames
0 Deferred frames 0 ValidOverSize frames
0 Gold frames dropped 0 FcsErr frames
0 Gold frames truncated
0 Gold frames successful
0 1 collision frames
0 2 collision frames
0 3 collision frames
0 4 collision frames
0 5 collision frames
0 6 collision frames
0 7 collision frames
0 8 collision frames
0 9 collision frames
0 10 collision frames
0 11 collision frames
0 12 collision frames
0 13 collision frames
0 14 collision frames
0 15 collision frames
0 Excess collision frames
Please can you tell me what is the exact meaning of these value
Port               InOctets            InUcastPkts     InMcastPkts   InBcastPkts
Gi2/0/24       34791793703       33910782         617344            0
Port              OutOctets         OutUcastPkts   OutMcastPkts  OutBcastPkts
Gi2/0/24      5344940713         26035075         1390844         34128
sh int gigabitEthernet 2/0/40
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
Last input never, output 00:00:40, output hang never
Last clearing of "show interface" counters 19w2d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 10930
from my this interface one server is connected...
why here total output drops.
can someone explain...
Jain,
What needs to be explained?  Joseph has already explained succinctly what is going on and what needs to be done.
but this is another , from this port my server is connected , why i am getting
