The problem for using VRF and NAT (Duplicated IP address)
WangSteven02215
I uploaded question in order to solve the problem. However, it is still living as a question, because it is not yet solved.
The help of network expert is necessary. Could you give me any help with that? Please refer to URL below. Thanks.
https://community.cisco.com/t5/routing/solution-for-network-connection-with-same-ip-address-nat-vrf-etc/td-p/4962580
But I answer you in that post and I will answer you again.
We will try do NAT
We have subnet x and subnet x
We need to config NAT
Ip nat inside source list xxx interface overload
The issue is list xxx is same for subet x and subnet x
Even if we divide the by vrf the NAat issue still same
What we need to do is
Use multi link between router and monitor
And make each link in single vrf
And then make each site in each vrf.
Hello
I have already  provided a possible solution to this post...please review it
Kind Regards
Paul
Paul, thank you very much for your support. I entered the commands referring to your explanation. However, It is still a problem. Please refer to URL below. Thanks.
