Threshold to set for device monitoring
Shahab Khan
Hi All,
Is there any document from Cisco suggesting what temperature threshold should be set for device monitoring?,
Shahab Khan
paulstone80
Level 3
Level 3
Hi Shahab,
If you download the Hardware Installation Guide for the device you want to monitor, it will tell you the acceptable operating temperatures for the device. You can then make a judgement from there as to the thresholds you would want to be alerted on.
HTH,
Paul
HTH Paul ****Please rate useful posts****
