Throttles on show interface command
DAVE GENTON
Level 2
Level 2
Since implementing qos and voip customer is seeing a large number of throttles on gig interfaces of his routers, what exactly is being throttled and what is considered high ??
thanks in advance,
andrew.prince
Level 10
Level 10
The traffic that is mathing the QoS policy is being throttled - and the configuration on the QoS defines what is high.
Check the config - all the information you need is in the config.
