Throughput issue
newtamil2011
Hi ,
The below is output of cisco 3845 router.As per cisco the capacity of process switching for this router is 17MB & fast switching is 256 MB.But when i checked the output of the router , It seems to be exceeding.Kindly clarify me whther the load is more for this router,
HBBCPMPLSR4#Show interfaces switching
GigabitEthernet0/0 *** LAN to 10.225.36.3 Gi1/22 ***
          Throttle count         22
                   Drops         RP     732275         SP          0
             SPD Flushes       Fast        156        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs   10230944      Drops          0
    Protocol  IP
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process   12677265 1298798700    7541150  783071826
            Cache misses         10          -          -          -
                    Fast 1811336467 2446870812 1441082749 2835012751
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                 Process          0          0        548      42196
            Cache misses          0          -          -          -
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process       1124      67440        205      12300
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process       6078    2765490       5473    2046902
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          0          0      32819    1969140
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    NOTE: all counts are cumulative and reset only after a reload.
GigabitEthernet0/1 *** RRI SLB to HBBCPR2 (10.225.36.6) Gi1/41 ***
          Throttle count       2482
                   Drops         RP     738343         SP          0
             SPD Flushes       Fast        104        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs    9067325      Drops        647
    Protocol  IP
                 Process   15644435 2428668156   15061839 2087501530
                    Fast 1441506223 1664217930 1812060658 1657842574
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process         68       4080         72       4320
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process       5466    2536224       5473    2046902
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
Loopback100
    Protocol  IP
                 Process      70897    4253820      70897    4253820
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
Thanks in advance
ebarticel
Level 4
Level 4
Check this post, last replay has a link to a info sheet which may help you.
https://supportforums.cisco.com/thread/205251
Eugen
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Performance specs often are for minimal size packets.  More "normal" size packets generally allow more throughput.
So, actual production input can be higher, although it can be lower too as additional service features impact CPU and you usually need to allow for duplex traffic.
