Time on switch does not match logs??
burleyman
Level 8
Level 8
I wrote to memory so I would get a log entry and then I did show clock and the times do not match.....why would that be?
here is the output
Dec 4 14:42:21: %PFINIT-SW1_SP-5-CONFIG_SYNC: Sync'ing the startup configuration to the standby Router.
6509-VSS#show clock
09:42:37.656 EST Thu Dec 4 2008
6509-VSS#
Thanks mike
Hello Mike,
I was meaning the following options
service timestamps log datetime ?
localtime Use local time zone for timestamps
msec Include milliseconds in timestamp
show-timezone Add time zone information to timestamp
I would add msec local-time
Hope to help
Giuseppe
Giuseppe Larosa
Hello Mike,
it should be a question of timezone
in the service timestamps log datetime command there are options to move to another timezone
or the timezone is missing in NTP config you see that minutes and seconds are good enough
Hope to help
Giuseppe
service timestamps debug datetime
service password-encryption
service counters max age 10
clock timezone EST -5
clock summer-time EDT recurring
ntp clock-period 17083848
ntp source Vlan1
ntp master 10
ntp update-calendar
ntp server xxx.xxx.xxx.xxx
6509-VSS#show ntp status
Clock is synchronized, stratum 2, reference is 192.5.41.40
nominal freq is 250.0000 Hz, actual freq is 251.4051 Hz, precision is 2**18
reference time is CCE27041.178D5020 (10:05:37.092 EST Thu Dec 4 2008)
clock offset is -2.0895 msec, root delay is 35.89 msec
root dispersion is 10.45 msec, peer dispersion is 7.89 msec
Here is parts of the config....am I missing something? NTP looks correct.
Mike
Hello Mike,
Hope to help
Giuseppe
Sorry....I understand now. It has been a rough couple days. Troubleshooting a high CPU % on this switch with no luck.
That worked... thanks.
Mike
