To block ping to nei switch
mahesh18
Level 6
Level 6
Hi all,
I want to block ping to switch which is connected to fa1/0 interface of router here is my config
access-list 103 deny icmp 192.168.1.1 0.0.0.0 192.168.1.10 0.0.0.0  echo host-unknown  log
access-list 103 permit ip any any
switch IP is 192.168.1.10
Router ip 192.168.1.1
Lan interface of router config
interface FastEthernet1/0
ip dhcp relay information trusted
ip access-group 103 out
i tried both   ip access-group 103 out   and in still ping is going?
thanks
mahesh18 wrote:
Hi jon
thanks for reply.
so on switch i can apply the acl like this on switch
2950T(config)#access-list 100 deny icmp 192.168.1.1 0.0.0.0 host 192.168.1.10 echo
2950T(config)#acce
2950T(config)#access-list 100 permit ip any any
2950T(config)#exit
now switch interface fa0/16 is connected  to router should i apply acl on fa0/16 on switch interface?
thanks
mahesh
Mahesh
If this is a 2950 switch you can't apply an IP address to an interface. What have you assigned the IP address to on the switch ?
If is a L3 vlan interface then apply it to that ie.
int vlan 10
ip access-group 100 in
Jon
Jon Marshall
mahesh18 wrote:
Hi all,
thanks
Mahesh
An acl applied outbound on a router interface does not filter traffic generated from that interface. So if you are pinging from the router it will still ping. If you pinged from a device connected to another interface on the router to the switch it should work.
Alternatively if you want to stop the router pinging the switch you need to apply the acl inbound on the switch.
Jon
Hi jon
thanks for reply.
2950T(config)#acce
2950T(config)#exit
thanks
mahesh
mahesh18 wrote:
Hi jon
thanks for reply.
2950T(config)#acce
2950T(config)#exit
thanks
mahesh
Mahesh
int vlan 10
Jon
Hi Jon,
thanks again.
Best regards
mahesh
