C6KPWR FRU power failed
jbarger
A blade on a 6509 shutdown over night due to temperature. The inlet was blocked by to a cable cover. The blade was out of the switch for 10 minutes and has cooled off. Actually the power to the blade has been off for 6 hours. Now that the blade has been reinstalled it doesn't power back up. I tried the command "power enable module 1" and when I "show power" I see the following for module 1.
1 WS-X6724-SFP 125.16 2.98 - - on off (FRU-power failed)
The powersupplies and the fan blade are working fine... Any ideas how to get this card to power on?
Joe
6 Replies 6
satish_zanjurne
Level 4
Level 4
1.If possible try installing this blade in another chassis , and see if it is working ??
2.If it is not working in another chassis also ,
then blade has gone failed , get it RMA/replaced ?
HTH...rate if helpful..
I don't have another chassis and it looks like the software is keeping power from coming up...
#power cycle module 1
% This command is being deprecated.
% Please use exec-level command :
% hw-module module reset
Proceed with reload of module? [confirm]
% module is operationally disabled
And the "w-module module 1 reset"command doesn't work.
#hw-module module 1 reset
% Invalid input detected at '^' marker.
It really looks like I should just upgrade the software on the switch since I will have to have downtime, YUK, But I hate changing two things at once.
Just FYI if you ever stumble upon this ticket trying to figure out the same error... TAC is sending a replacement blade.
And the blade also had the same error in a different slot in the same Chassis.
It did turn out to be the blade... The new one works fine.
Hi jbarger,
          I have the same problem. Please, what did you do? Could you explain in detiail to me???
Thank you very much.
Elvis Marques www.avvid.net
It was broken so I got a new one.
