To see if nxapi feature enabled or not
Arijit007
I have few switches for which i want to see if nxpai feature enabled or not. These are Cisco Nexus 3000 Series, Cisco Nexus 3064 PQ Switch, Nexus 56128P switches. Now I have run the below command but upon execution it gives no output. What other ways to check if that feature enable or not??
command ran: show feature | include nxapi
marce1000
 - No output probably means not enabled you may also try show nxapi
 M.
Thanks for the input. I have one doubt if you can help. I am new to this field. May be it is silly to ask but I just wanted to know.
Nexus 5600 and Nexus 56128P are these a different series family or falls under 5600 series family? similarly
Nexus 3000 and 3064 PQ are they different series family or falls under 3000 series family?
in very general terms, the entire family/series of switches is numbered as Nexus 5600 and Nexus 3000. Anything that starts with Nexus 56xx and Nexus 3xxx is part of that series/family.
Thanks for the information. I have one more question. It would be very helpful--
What is the command to see smart licensing, smart call home feature status for CISCO switches and Terminal servers?
