TOR - Top Of Racks Switches
Edson Vuma
Hi, Guys.
I have on my datacenter a Cisco Catalyst 4500, which we use as Core Swtches on some racks.
Now Im looking for some switches to use as TOR - Top Of Rack with 10Gbps, on other racks.
Any suggestions on which models can be suitable for my situation?
Warm regards
/EV
-- Regards Edson Vuma
5 Replies 5
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Nexus switches are designed for data center including TOR models.
The earlier 49xx series also work pretty well as TOR models.
Hi, Joseph
Thanks for your reply.
Kindly, can you tell me if I keep the Cisco 4500 Series (Cisco cat4500e) switches as Core, is it possible to use Nexus Switches as TOR and interconnecting the racks with fiber?
Are they compatible?
If not, kindly, what would be the best solution for TOR Switches?
Thanks for your attention.
Warm regards
/EV
Disclaimer
Posting
Sure, you can keep the 4500 as a core.  Just be careful about over subscription, as data center devices often are "busier" than user edge devices.
Yes, you should be able to interconnect with fiber if devices have compatible fiber ports.
Hi, Joseph.
Thanks for your clarification once again.
Kindly, can you tell me which NEXUS Top Of Rack Switch models are compatible with Cisco 4500 as Core?
Warm regards,
Edson Vuma
Disclaimer
Posting
Any.
