Total Output Drops - Very High. Cisco C3560X
hutcha4113
Looking for some assistance on an issue we are seeing with a Cisco C3560X.  All of our branch switches have the same configuration, however this particular Branch Switch is generating an alert in Solarwinds, with a high number of Discards.  I believe Discards in SW relate to show interface value -> Total Output Drops (I believe anyway).
Running 15.0(2) SE8 UniversalK9-M
Here is the configuration of a sample standard access port:
interface GigabitEthernet0/5
 description ****Standard Access Port****
 switchport access vlan 10
 switchport mode access
 switchport voice vlan 11
 no logging event link-status
 srr-queue bandwidth share 1 70 25 5
 srr-queue bandwidth shape 30 0 0 0
 priority-queue out
 no snmp trap link-status
 mls qos trust dscp
 storm-control broadcast level 15.00
 storm-control action shutdown
 no cdp enable
 no lldp transmit
 no lldp receive
 spanning-tree portfast
Here is the show interface for this port:
show interface gigabitEthernet 0/5
GigabitEthernet0/5 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 6c99.89e7.9105 (bia 6c99.89e7.9105)
  Description: ****Standard Access Port****
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:07, output hang never
  Last clearing of "show interface" counters 1d00h
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 7844280
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 89000 bits/sec, 50 packets/sec
  5 minute output rate 239000 bits/sec, 141 packets/sec
     145793 packets input, 30710632 bytes, 0 no buffer
     Received 810 broadcasts (423 multicasts)
     0 watchdog, 423 multicast, 0 pause input
     4038005 packets output, 428508100 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
I have highlighted the total output drops, as I believe that is generating the Alert.  It is also crazy high, compared to any of our other switches.
Should also note we are using this configuration everywhere, and it works fine at other locations, with the same type of devices plugged in.  Here is an example of another Branch Office, and what its traffic looks like:
show interface gigabitEthernet 0/3
GigabitEthernet0/3 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is ccd8.c16d.2d03 (bia ccd8.c16d.2d03)
  Last input never, output 00:00:04, output hang never
  5 minute input rate 2000 bits/sec, 3 packets/sec
  5 minute output rate 2000 bits/sec, 3 packets/sec
     2220922 packets input, 181965988 bytes, 0 no buffer
     Received 242314 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     13828206 packets output, 1348934099 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
These switches are the same model, running the same IOS version - pretty much identical in every way, accept for the Physical Location.  Any thoughts on why I am seeing such an issue?
Reza Sharifi
Is the device connected to port 0/5 supposed to operate at 100Mb or Gig?
Also, here is a link on troubleshooting output drops:
http://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/6343-queue-drops.html
All devices connected to this switch are 100MB/Full Duplex.  They seem to be negotiating fine.  I should also advise it is not just port 5 on the switch - pretty much every port is generating the same thing.
haver you tried turning off mls qos , it can cause issues like this , what are the statistics for the qos queues are any of them over utilized seeing drops , have you tried tweaking the buckets in mls ?
3560s also have very low buffers so if any of the devices connected to this are using apps which can cause burst traffic it fills the buffer instantly causing output drops , they can be legitimate depending on the traffic patterns in place
you can check for micro bursts through wire shark , it may be software rather than the switch causing it , also could be mls
https://notalwaysthenetwork.com/2014/01/06/microburst-detection-with-wireshark/
