tracerouting through a tunnel question
lgontarsk
Hi, there's something I don't understand.... when you have a tunnel interface, and traceroute to the tunnel destination - why don't you get the hops inbetween the tunnel - the real hops that the tunnel is being formed over?
Thanks, LisaG
2 Accepted Solutions
chrihussey
Becuase the ICMP packets are encapsulated (or enveloped) inside GRE packets and are never seen by the intermediate routers. Only when the tunnel destination is reached is the packet de-encapsulated.
If you want to trace the tunnel's path trace to the tunnel destination and not the tunnel's interface IP.
Lisa
If you want to put in a static route that will carry traffic through a GRE tunnel then the next hop in the static route should be the tunnel interface address of the remote router.
Rick
Rick
chrihussey
THANKS!
By the same token, if you want to put in a static route to through an IPSEC/GRE tunnel, is the next hop supposed to be the tunnel destination, the ipsec peer or the next hop in the physical path?
THanks, Lisa G
Lisa
Rick
Rick
