Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
We have 2 internet links with different service providers.Everything is working fine.
Default Static route on L3 is pointing to F/W 1 (to pass Traffic thro ISP1)
Now the problem is If ISP1 link went down or Tunnel went down, Manually we need to remove static route
pointing to F/W 1 & add static route pointing to 2nd F/W.(to pass traffic thro ISP2).
Can i implement configuration in L3 switch with IP SLA in such a way that Auto switch over Happens when ISP1 internet link goes down.(without Administrator )
Yes, that's one of the options you have. IP SLA will track the route based on the defined parameters. If your primary link fails, the tracked object fails & IP SLA will automagically withdraw the tracked route from the routing table.
One thing to check, make sure your platform supports IP SLA at first. Below is the config which may defer based on your platform.
ip sla 1 icmp-echo 4.2.2.2 source-ip
frequency 30 ip sla schedule 1 life forever start-time now ip sla enable reaction-alerts
track 1 ip sla 1 reachability
ip route 0.0.0.0 255.255.255.0 1.1.1.1 track 1
ip route 0.0.0.0 255.255.255.0 2.2.2.2 100
ip route 4.2.2.2 255.255.255.255 1.1.1.1
Notice that i am sending pings to 4.2.2.2 (a global DNS server) because it rarely goes down. So what happens now is, if your primary link goes down, IP SLA fails reaching 4.2.2.2 & it withdraws the tracked route from the routing table (i.e
ip route 0.0.0.0 255.255.255.0 1.1.1.1 track 1). It now adds back the another one with the higher metric into the routing table (i.e ip route 0.0.0.0 255.255.255.0 2.2.2.2 100) .
Make sure you have a static route to 4.2.2.2 always pointing to the primary ISP because if primary comes back online IP SLA will re-instate this path again into the routing table (kind of pre-emption).
Hope this helps.
Vivek
Learn, share, save
