Traffic encryption
mdjan
Level 2
Level 2
Hello Guys,
I would like to interconnect to site via fiber optic en mode peer to peer. It is possible to encrypt all traffic on this link? which king of router/firewall we should use? And how to do traffic encryption without VPN?
THANKS
Julio E. Moisa
You could create a GRE tunnel with IPSEC. Take in consideration you must configure the MTU and TCP mss, in order to avoid inconveniences.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
6 Replies 6
Julio E. Moisa
Hope it is useful
Thank for your reply
I already think about that idea at first but I was not sure if it was the good designing in this case which is a peer to peer connection.
Yes, it can be considered as part a good design, the following link can be useful:
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/WAN_and_MAN/P2P_GRE_IPSec/P2P_GRE/2_p2pGRE_Phase2.html
Thank eduardomoi
It was a pleasure, have a great day.
In situations like these, I would go for MACsec where the switches do the link-encryption. This can achieve line-rate encryption where a firewall would need to be very good sized.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
