TRAFFIC LOAD SHEARING
suhas_syndrome
HI,
Please find the topology below is it write config to use both link simultaneously... (TRAFFIC LOAD SHEARING)
Suhas
I would check first what the real metric is.
show ip route 172.16.10.1 e.g.
if you need to double the metric to use both links,
the variance should be correct, yes.
but for traffic sharing you have to add this command:
traffic-share balanced
mabye you check that Link too if my post is not enough for you.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009437d.shtml#var
_________________
pls. rate if helpful
traffic-share balanced is the default behavior though.  So he needs that command or not depends on how the interfaces are configured no?
