Translate configuration from HP to Cisco
tetcwork
I am very new to Switch world.  I have a task to migrate from HP switch to Cisco switch but I'm not familiar with the HP configuration. I wanted to make sure that what I have is correct so there is no hiccups when migration happens.
Gi1/0/1 is the uplink to the main switch.
Config on HP:
hostname "Switch1"
ip default-gateway 10.10.10.1
exit
vlan 1
name "DEFAULT_VLAN"
no untagged 4-26
untagged 1-3,27-52
ip address dhcp-bootp
ipv6 enable
ipv6 address dhcp full
exit
vlan 100
name "PHONE"
untagged 4
tagged 1-3
no ip address
voice
vlan 300
name "VLAN300"
untagged 5-26
tagged 1-3
no ip address
exit
vlan 800
name "VLAN800"
tagged 1-3
no ip address
exit
vlan 900
name "MANAGEMENT"
tagged 1-3
ip address 10.10.10.250 255.255.255.0
exit
no tftp server
no autorun
no dhcp config-file-update
no dhcp image-file-update
no dhcp tr69-acs-url
password manager
Here is what I have for Cisco:
hostname Switch1
vlan1
name DEFAULT
vlan 100
name Phone
Vlan 300
name VLAN300
vlan 800
name VLAN800
vlan 900
name MANAGEMENT
int vlan 1
ip address dhcp
int vlan 900
int range Gi1/0/1-3
switchport mode trunk
switchport trunk allow vlan 100,300,800,900
int Gi1/0/4
switchport mode access
switchport access voice vlan 100
int range Gi1/0/5-26
switchport access vlan 300
Question:
1. Do I have to allow vlan 1 in the trunk?
2. Does the configuration for the Cisco switch look ok?
Reza Sharifi
No, vlan1 is the native vlan, and you don't to specify it in the trunk
Thank you.
Does the configuration I have look ok?
Looks correct to me.
Just one thing. It looks like you are using vlan 900 as your management vlan. In this case, you can simply shut down vlan1. It is a good practice not to use vlan1.
int vlan 1
sh
