Trouble with configuring DHCP with OSPF
Cisco2882
Hello, I am writing to you because I am having trouble configurign DHCP with OSPF. My network is set up like so:
http://i.snag.gy/uVRhe.jpg
My show run output for router 1 is currently:
interface FastEthernet0/0
ip address 200.10.10.97 255.255.255.224
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 200.10.10.1 255.255.255.252
clock rate 64000
interface Serial0/0/1
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.0.0.0 0.0.0.3 area 0
For the company router I have:
ip dhcp excluded-address 210.10.10.33 210.10.10.38
ip dhcp pool lan-a
network 200.10.10.32 255.255.255.224
default-router 200.10.10.33
dns-server 200.10.10.255
ip dhcp pool lan-b
network 200.10.10.64 255.255.255.224
default-router 200.10.10.65
ip dhcp pool lan-c
network 200.10.10.96 255.255.255.224
default-router 200.10.10.2
spanning-tree mode pvst
ip address 200.10.10.33 255.255.255.224
duplex auto
speed auto
ip address 200.10.10.65 255.255.255.224
duplex auto
speed auto
ip address 200.10.10.2 255.255.255.252
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
network 10.0.0.0 0.255.255.255 area 0
Any help would be appriciated, as I have been trying to get this to work for the last few hours.
Rolf Fischer
Level 9
Level 9
Hi Nick,
I guess DHCP doesn't work for LAN-C / PC4?
PC4 sends DHCP Discover messages as Layer-2 broadcast, so the LAN-interface on Router 1 needs to act a a DHCP relay-agent, which is configured with the ip helper-address command.
Next step is connectivity between Router1 and the Company-Router. You have OSPF enabled for interfaces with a 10/8 IP-address but all the configured interface's IPs start with 200 or 210. Make sure that the Company-Router is able to reach Router1's LAN-interface by enabling OSPF for the 200 and 210 networks.
Finally you should exclude the LAN-interface of Router1 (.97) from the dynamic DHCP pool as well.
Rolf
