WS-2960S-48TS-S upgrade IOS problem !!!
huga16001
hi, WS-2960S-48TS-S switch upgrade IOS:
          Current IOS: c2960s-universalk9-mz.122-58.SE2.bin
          Upgrade IOS: c2960s-universalk9-mz.150-2.SE2.bin
switch: boot flash:c2960s-universalk9-mz.150-SE2.bin
Loading "flash:c2960s-universalk9-mz.150-SE2.bin" ...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:c2960s-universalk9-mz.150-2.SE2.bin" uncompressed and installed, entry point: 0x3000
executing...
Boot process failed...
switch:
what is problem ?????
help me !!! thanks all.
18 Replies 18
Leo Laohoo
c2960s-universalk9-mz.150-2.SE2.bin < --- This file is corrupt.
Karthick Murugan
It looks the file is corrupted. Execute dir flash: and check the size of the file and match it with the file size in the CCO.
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
Thanks, Leo Laohoo and karthick Murugan
i am download from
http://software.cisco.com/download/release.html?mdfid=282867583&flowid=46699&softwareid=280805680&release=15.2.1E&relind=AVAILABLE&rellifecycle=ED&reltype=latest
so, this is source file,
the same problem ?
Switch#dir flash:
Directory of flash:/
    9  -rwx        2458   Mar 1 1993 00:00:53 +00:00  config.text
    2  -rwx    13244928   Jan 1 1970 00:01:09 +00:00  c2960s-universalk9-mz.122-58.SE2.bin
    3  -rwx    16353536  Nov 18 2013 15:59:16 +00:00  c2960s-universalk9-mz.152-1.E.bin
    4  -rwx        3096   Mar 1 1993 00:00:53 +00:00  multiple-fs
    5  -rwx         108   Mar 1 1993 00:29:43 +00:00  info
    6  -rwx        2421   Mar 1 1993 00:01:00 +00:00  config.old
    8  -rwx        1914   Mar 1 1993 00:00:53 +00:00  private-config.text
57931776 bytes total (28078592 bytes free)
Switch#
this IOS  // c2960s-universalk9-mz.152-1.E.bin  //
switch: boot flash:c2960s-universalk9-mz.152-1.E.bin
Loading "flash:c2960s-universalk9-mz.152-1.E.bin" ...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
executing...
switch:
Thanks all, help me
Picture:
My money would be on a corrupt IOS.
Firstly try downloading again and copy over to the switch.
If that still fails, try a different IOS version, i.e one up or one down.
I had an issue with a 3750X and a 15.* image and it would not boot for love nor money. Tried the IOS down from the one I was using and it seemed fine....weird but sometimes you get odd things happen
Post the output to this command:
1.  sh version;
2.  verify /md5 flash:c2960s-universalk9-mz.152-1.E.bin e5579f9e888968b0fdd0c2abea23ee7b
hi all, thanks for help me
Leo Laohoo, this is fine
but, this IOS is dependency clock ?? My switch time :
Time doesn't need to be synch or correct.  Output shows the file is OK.
Can you boot this file:  c2960s-universalk9-mz.122-58.SE2.bin
If you can, then try a different IOS.  Try 15.0(2)SE4.
    i can my current IOS c2960s-universalk9-mz.122-58.SE2.bin no problem,
Then try using 15.0(2)SE4 instead.
c2960s-universalk9-mz.150-1.SE3.bin IOS is OK
I would not use 15.0(1)SE even if my life depended on it!
I repeat, use 15.0(2)SE4.
Thank you Leo Laohoo,
     i think, Cisco IOS dependence HV (hardware version 04) not support for c2960s-universalk9-mz.152-1.E.bin
, my switch HV (V04),
     help me, check your switch HV !
     thanks, for all
I am not running 15.2(1)E and I will NOT touch 15.2(1)E.
