Troubles extending LAN over Cisco 2621
ritch
Hi folks,
i'm trying to do something that i'm guessing should be quite simple. i'm setting up a small LAN inside a LAN. the equipment is this;
Cisco WS-C2912-XL (vlan 1 ip address 10.0.0.9) -> Cisco 2621 -> Host
Below is the running configuration i've set up on the 2621. i usually connect my host (laptop) to the 2912 and all is good in the world. there's something i'm sure quite small and obvious that i'm missing out to enable the router to bridge between the two. with this setup i'm able to receive an ip address from dhcp, and the router can ping the gateway router to the internet 10.0.0.1 but i'm unable to get internet access or access to my network.
i've not configured any access lists as this part has been enough of a stumbling block already, hence the fairly base configuration. if anyone can tell me what the problem might be it would be greatly appreciated.
thanks,
nick
nick#sh run
Building configuration...
Current configuration : 827 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname nick
enable secret xxx
ip subnet-zero
ip domain-name nsw.bigpond.net.au
ip name-server 61.x.x.14
ip name-server 61.x.x.15
ip dhcp excluded-address 10.10.0.10
ip dhcp pool nick
network 10.10.0.0 255.255.255.0
dns-server 61.x.x.14 61.9.192.15
default-router 10.10.0.10
lease 7
interface FastEthernet0/0
ip address 10.0.0.10 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.0.10 255.255.255.0
ip helper-address 10.0.0.1
duplex auto
speed auto
router rip
network 10.0.0.0
ip classless
ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
password password
login
line vty 5 15
password password
login
no scheduler allocate
end
nick#
Roberto Salazar
Level 8
Level 8
More questions:
1. which subnet is not able to get to the Internet?
2. can the hosts not able to get to the internet able to ping the gateway to the Internet?
3. I do not see any NAT and you are using private IP addresses, I assume the NATing is going on somewhere else, so make sure the device doing the NATing is NATing for that subnet.
4. make sure the gateway have a route back to the subnet not able to get to the Internet.
Pleaes rate helpful posts.
Roberto Salazar
Level 8
Level 8
More questions:
1. it was the 10.10.0.0 subnet unable to get access, the host (10.10.0.1 by dhcp) could ping the gateway to the internet (10.0.0.1, which handles the NAT).
It's a Netgear router that is the internet gateway, i was unable to figure out how to affect the NAT on that, but when i added the route to the affected subnet it got me up and running.
Thank you very much bosalaza, that's the fix, cheers for the knowledge,
Nick
micahcox
Add the configuration line
ip route 0.0.0.0 0.0.0.0 10.0.0.1
to your cisco router so it knows where to send routes not on your 10.10.0.0 255.255.255.0 subnet.
Then go onto your Netgear router and enter a static route for 10.10.0.0 255.255.255.0 and tell it the next hop is 10.0.0.10.
That should do it. Go ahead and doublecheck to make sure the mask on the netgear box for 10.0.0.0 is 255.255.255.0 as well.
Those two routing entries assure each router knows how to get to the other. If the netgear supports RIP version 2 then you can turn it on both routers instead of the static routes. RIPv1 won't do it because it doesn't support classless subnets.
rameshwarhiwale
use static routes. i have doubt hv u configured dns anywhere in network.
