Home Lab: Cannot Ping PC from Router
cindy2000
Hello, I am new here to the boards. I recently pieced together a home lab.
I am unable to ping my PC from my 2500 router. I have it connected through a console cable. I can send commands to the router and configure it. I have Ethernet 0 setup on the same subnet as the PC. No shutdown and no keepalive.
PC side is WinXP with "no firewall" and alow ICMP requests.
I am still unable to ping my PC which is driving me crazy!
I am sorry for being sch a noob. I have tried searching and nothing has helped yet.
Please assist, thank you =)
9 Replies 9
cindy2000
I am trying to connect to PC 10.248.19.106 255.255.255.0
Tried Auto and 10mb
Here is my show config:
interface Ethernet0: Interface Serial0
ip address 10.248.19.1 255.255.255.0wn
interface Ethernet1
ip address 10.248.0.1 255.255.255.0
no keepalive
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
no ip classless
snmp-server community y RO
<-- show ip int -->
Ethernet0 is up, line protocol is up
Internet address is 10.248.19.1/24
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is enabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is disabled
IP multicast fast switching is enabled
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
Probe proxy name replies are disabled
What happens when you try to ping router from your PC?? Does that go through??
Can you please paste the output of "Show running int Ethernet0" and "Show int Ethernet 0" from your router and "ipconfig/all" from your PC?
AbhisheK
Cindy,
Just to check, maybe you have ip routing globally disabled. If so, add ip routing to the config.
Just after you ping, try a show arp. Can you see the MAC address of your PC in the table?
Kevin Dorrell
Luxembourg
Did you set GW for your PC - it should be work without it, but nobody knows MS XP :). Just one probe.
Anyway I hope your interface is in "up up" state. Did you checked?
Bye
FCS
Please rate me if I helped.
(1)make "no ip classless" to "ip classless"
make "no keepalive" to "keepalve 10"
(2)Then give the output of "sh int e0"
(3)On tranreciever make sure that the button "sqe" is off.(if its there)
(4)Is the crossover cable working ok.
JD
why no keepalive & r u usint crossover cable to connect router & PC.
clbitzer
your pc is connected to the console port. You have an en port on your pc (pcmcia card or internal port) that is configured with an IP address and snm in range of ethernet port subnet on router? The en port on 2500 router is configured, and plugged into a hub or sw by a tranciever and cable? Your pc is plugged into the same hub/sw with another straight thru en cable. Please confirm. Otherwise, from the console port you do not have the ability to ping your pc ethernet interface if the pc en interface is not on a lan.
rameshwarhiwale
hi Cindy, pls check the following
1) Is PC is connected to router through ethernet cable.
2)Icon on ur PC is showing connected.
3) LED of both ethernet cards are blinking.
4)check sh arp on router, if the mac of ur PC is is showing on ur router then check netbios settings.
rameshwarhiwale
