troubleshooting
alain.bider
I count one your expereience to find out where this errors are coming from:
FastEthernet41 is up, line protocol is up
Hardware is epif_port, address is 0005.32fb.412f (bia 0005.32fb.412f)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, rely 253/255, load 1/255
Encapsulation ARPA, loopback not set, keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX
Last input 00:00:01, output 00:00:00, output hang never
Last clearing of "show interface" counters 18w2d
Queueing strategy: fifo
Output queue 0/40 (size/max)
5 minute input rate 2000 bits/sec, 2 packets/sec
5 minute output rate 3000 bits/sec, 5 packets/sec
73011291 packets input, 3179264223 bytes, 0 no buffer
Received 419977 broadcasts, 645282 runts, 3547 giants, 0 throttles
6189442 input errors, 3007274 CRC, 2533339 frame, 0 overrun, 0 ignored, 0 abort
0 watchdog, 18 multicast
83904450 packets output, 2814502170 bytes, 0 underruns
0 lost carrier, 0 no carrier
Thanks for your input
Alain
Georg Pauwen
Hello Alain,
check if the device that is connected to this port is set to 100MB and Full Duplex fixed and not autonegotiation.
Also, try and change the Ethernet cable connecting to the device.
It could also be the NIC of the device connected that is faulty, or the switchport itself. Try to connect the device to another switchport, and if that does not help, try and exchange the NIC.
What do you have connected to the port anyway ? There is a document that describes NIC compatibility issues with Catalyst switches, you might want to check this:
Troubleshooting Cisco Catalyst Switches to NIC Compatibility Issues
http://www.cisco.com/warp/public/473/46.html
GP
