Trunk help
whiteford
Hi, based on:
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a00800949fd.shtml
A little progress, the trunk is nearly working I think, but both PC's can't ping each other.
I have a PC (PC A) with:
IP address - 192.168.2.50
Gateway - 192.168.2.1
In FE 0/9 of switch VLAN10
I have a PC (PC B) with:
IP address - 192.168.3.10
Gateway - 192.168.3.1
In FE 0/17 of switch VLAN20
PC A can ping 192.168.2.1 and 192.168.3.1
PC B can ping 192.168.3.1 but NOT 192.168.2.1
What could this be?
20 Replies 20
Hello Andy,
I was meaning
sh int fas0/1 switchport
Excuse me for not having typed an enter before.
I got it :
no ip routing
in the router config
you need to turn ip routing on the c2600
conf t
ip routing
Hope to help
Giuseppe
Well done.
I'm sorry I missed that too.
For my understanding Guiseppe, does the native vlan play any role in this setup? I'm confused why it is required?
Also I want to draw this netork diagram for my documentation, do you know of a tool that can do this that's free?
Here is the info anyway that you wanted :)
Switch#sh int fas0/1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
How would I now set this up so I can telnet to the switch from the users VLAN 10?
Hello Andy,
on the switch you just need to create an SVI for vlan 10
int vlan 10
ip address ....
no shut
the address must be in ip subnet associated to vlan 10.
Hope to help
Giuseppe
SVI, is this a sub vlan interface? So o I create this on the switch:
int vlan 10
ip address ....
no shut
Then on the router aswell or just the switch and does the switch need a gateway?
Hello Andy,
only on the switch and then you are right you need to specify the router ip address in vlan 10 as the default-gateway for the switch
int vlan 10
ip address 192.168.2.x
no sh
where x stays for the last byte and is what you want among the free addresses.
ip default-gateway 192.168.2.1
Sorry for the missing info
Hope to help
Giuseppe
