Trunk Interface detecting PoE
gabsnet
Frequent Visitor
Frequent Visitor
Has anyone seen that cisco behaviour ?
I've got two devices connected to each other via Ethernet port, trunked.
Core: WS-C3750X-48P  15.2(4)E10 connecting to Secondary: WS-C3750X-48P 15.2(4)E10.
And I've got alerts on the Core SW that is detected PoE.
%ILPOWER-5-IEEE_DISCONNECT: Interface gi1/0/47: PD removed
%ILPOWER-7-DETECT: Interface gi1/0/47: Power Device detected: IEEE PD
Can you guys think any reason why that would happen?
I simply disable the power inline on my trunk interface, as it was causing disconnections and I think might have affected the STP too.
Mark Elsen
  - @gabsnet              Post the running configuration of  gi1/0/47
                                  Use the command show cdp neighbors detail on both switches and look
                                                at the reported info's for the trunk ports
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hello Mark.
See the configs:
---CORE SW
interface GigabitEthernet1/0/47
description DOWNLINK-MAZDA-PARTS
switchport trunk native vlan 100
switchport mode trunk
power inline never
FSA-SPT-MZ-SW-01#sh cdp neighbors g1/0/47 detail
Device ID: FSA-SPT-MZ-SW-02
Entry address(es):
IP address: X.X.X.X
Platform: cisco WS-C3750X-48P, Capabilities: Switch IGMP
Interface: GigabitEthernet1/0/47, Port ID (outgoing port): GigabitEthernet1/0/48
Holdtime : 142 sec
Version :
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.2(4)E10, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Tue 31-Mar-20 13:22 by prod_rel_team
advertisement version: 2
VTP Management Domain: 'JFAG'
Native VLAN: 100
Duplex: full
Management address(es):
IP address: X.X.X.X
Total cdp entries displayed : 1
---SECONDARY SW
description UPLINK-MZ-SW01
spanning-tree port-priority 16
end
FSA-SPT-MZ-SW-02#sh cdp neighbors g1/0/48 detail
Device ID: FSA-SPT-MZ-SW-01
Entry address(es):
IP address: X.X.X.X
Interface: GigabitEthernet1/0/48, Port ID (outgoing port): GigabitEthernet1/0/47
Holdtime : 139 sec
Version :
Native VLAN: 100
Duplex: full
IP address: X.X.X.X
  -  @gabsnet          Remove the power inline never directive from Gi1/0/47
  M.
pieterh
>>> Can you guys think any reason why that would happen? <<<
no not really, a 3750 should not present itself as a PD, only as PSE
there are some switches that can be powered over PoE and so be a PD but the 3750 is not one of those
maybe an external PoE(+)  injector is accidentally connected in the path?
