Trunk link flap bw router and switch
satya mothukuri
Hi Team,
Iam having problem with trunk link bw rourt and switch, am getting this messages on router.
Jan 11 11:34:48.765 MST: %DTP-5-TRUNKPORTON: Port Fa2 has become dot1q trunk
Jan 11 11:34:48.893 MST: %DTP-5-NONTRUNKPORTON: Port Fa2 has become non-trunk
Jan 11 11:34:50.873 MST: %DTP-5-TRUNKPORTON: Port Fa2 has become dot1q trunk
Jan 11 11:34:51.065 MST: %DTP-5-NONTRUNKPORTON: Port Fa2 has become non-trunk
Jan 11 11:34:52.381 MST: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to up
Router config:
interface FastEthernet2
description connection to c3560-1a1.u71006 switch
switchport trunk allowed vlan 1-4,99,100,195,199,1002-1005
switchport mode trunk
switchport protected
end
version
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
ROM: System Bootstrap, Version 12.3(8r)YH5, RELEASE SOFTWARE (fc1)
System image file is "flash:c181x-advipservicesk9-mz.124-24.T1.bin"
q71006lan1#sh int f2 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: 1-4,99,100,195,199,1002-1005
Trunking VLANs Active: 1-4,99-100,195,199
Protected: true
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
Swich config:
interface FastEthernet0/24
description uplink to q71006lan1 router
switchport nonegotiate
logging event trunk-status
logging event spanning-tree
end
c3560-1a1#       sh int f0/24 switchport
Switchport: Enabled
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: true
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Satya.M
satya mothukuri
Hi, plz let me know if any one know wr the issue..
Hi Satya,
Try enabling the "DTP trunk negotiation" on all ports..
Let me know how you go with it.
Please rate this post if helpful
