Trunk VLANs from Catalyst 3750x to Nexus 5548UP
Gelliston
I currently have a Core stack of 2 Catalyst 3750X.  I purchased 2 Nexus 5548UP to hang off the Ten Gigabit modules of the 3750 stack.  I am having trouble getting the VLANs on the 3750 to trunk over to the 5Ks.  I have configured the up links on the Nexus switches as I have on the rest of my Catalyst switches and I can not get the 5K to show the VLANs.  Any help on how to do this would be appreciated.  Most of the information I have found is trunking vlans to a 3750 from a 5k.  I need 3750 to a 5K.  Thanks!
5 Replies 5
Could you please share the configuration of the interfaces from both sides.
Also have you created the vlan's on N5K? If already created and still not working, try manually allowing the vlan over trunk.
switchport trunk allowed vlan <vlans you like to allow>
Madhu.
I did not create the VLANs on the 5Ks.  I need those VLANs to come from the 3750 Stack
*****3750 X Core stack ******
interface Port-channel20
switchport mode trunk
interface TenGigabitEthernet1/1/1
channel-group 20 mode active
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface Vlan1
no ip address
shutdown
interface Vlan3
ip helper-address 192.168.1.27
interface Vlan4
ip address 192.168.20.1 255.255.255.0
interface Vlan5
ip address 192.168.25.1 255.255.255.0
interface Vlan6
ip address 192.168.35.1 255.255.255.0
interface Vlan7
ip address 192.168.40.1 255.255.255.0
interface Vlan10
ip address 192.168.30.1 255.255.255.0
interface Vlan104
ip address 192.168.21.1 255.255.255.0
********Nexus 5K TOR-1***********
Nexus-5548UP-TOR-1(config-if)# sh cdp nei
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
S - Switch, H - Host, I - IGMP, r - Repeater,
V - VoIP-Phone, D - Remotely-Managed-Device,
s - Supports-STP-Dispute
Device-ID Local Intrfce Hldtme Capability Platform Port ID
Core_Stack mgmt0 150 R S I WS-C3750X-48 Gig1/0/25
Nexus-5548UP-TOR-2(SSI1920006P) Eth1/31 154 S I s N5K-C5548UP Eth1/31
Nexus-5548UP-TOR-2(SSI1920006P) Eth1/32 154 S I s N5K-C5548UP Eth1/32
Core_Stack Eth2/15 145 R S I WS-C3750X-48 Ten2/1/1
Core_Stack Eth2/16 151 R S I WS-C3750X-48 Ten1/1/1
Nexus-5548UP-TOR-1(config-if)# sh vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 2
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled (timeout = 240 seconds)
vPC Peer-link status
id Port Status Active vlans
1 Po1 up 1
vPC status
id Port Status Consistency Reason Active vlans
15 Po15 up success success 1
16 Po16 up success success 1
interface port-channel15
speed 10000
vpc 15
interface port-channel16
speed 10000
vpc 16
interface Ethernet2/15
channel-group 15
interface Ethernet2/16
channel-group 16
******Nexus 5K TOR-2****
Nexus-5548UP-TOR-2(config-if)# sh vpc
Legend:
vPC domain id : 1
vPC role : secondary
1 Po1 up 1
vPC status
speed 10000
vpc 15
speed 10000
vpc 16
channel-group 15
channel-group 16
What is ur VTP status on 5K and 3750?
sh vtp
Also from 5k, can you share the below
sh int po 15 trunk
I think I am making progress here.  It appears the VLANs are trunking now.  When I do a sh vlan on the 5Ks I get all my vlans.  However when I try to change an interface to access mode and assign a vlan that port does not work.  I attached the sh ru int eth2/1 below as well.
Nexus-5548UP-TOR-1(config-if)# sh vtp status
VTP Status Information
VTP Version : 2 (capable)
Configuration Revision : 21
Maximum VLANs supported locally : 1005
Number of existing VLANs : 13
VTP Operating Mode : Server
VTP Domain Name : Cisco
VTP Pruning Mode : Disabled (Operationally Disabled)
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 Digest : 0x7D 0x11 0x1A 0x0B 0xBD 0x1D 0xB7 0xD0
Configuration last modified by 192.168.1.1 at 8-29-93 12:17:21
Local updater ID is 0.0.0.0
VTP version running : 1
Nexus-5548UP-TOR-1(config-if)# sh int po15 trunk
Port Native Status Port
Vlan Channel
Po15 1 trunking --
Port Vlans Allowed on Trunk
Po15 1-4094
Port Vlans Err-disabled on Trunk
Po15 3-7,10,20,104
Port STP Forwarding
Po15 1
Port Vlans in spanning tree forwarding state and not pruned
Port Vlans Forwarding on FabricPath
Po15 none
Nexus-5548UP-TOR-1(config-if)# sh int po16 trunk
Vlan Channel
Po16 1 trunking --
Po16 1-4094
Po16 3-7,10,20,104
Port STP Forwarding
Po16 1
Po16 none
Nexus-5548UP-TOR-2(config-if)# sh vtp status
Nexus-5548UP-TOR-2(config-if)# sh int po15 trunk
Vlan Channel
Po15 1 trunking --
Po15 1-4094
Po15 3-7,10,20,104
Port STP Forwarding
Po15 1
Po15 none
Nexus-5548UP-TOR-2(config-if)# sh int po16 trunk
Vlan Channel
Po16 1 trunking --
Po16 1-4094
Po16 3-7,10,20,104
Port STP Forwarding
Po16 1
Po16 none
Core_Stack#sh vtp status
VTP Version capable : 1 to 3
VTP Traps Generation : Enabled
Device ID : a44c.11ff.2600
Local updater ID is 192.168.1.1 on interface Vl3 (lowest numbered VLAN interface found)
Feature VLAN:
MD5 digest : 0x7D 0x11 0x1A 0x0B 0xBD 0x1D 0xB7 0xD0
0xF2 0x39 0x28 0xEA 0x7A 0xE5 0x4D 0xB2
switchport access vlan 3
As you can see
Po16 3-7,10,20,104
there is a problem on your N5k. Please share full network diagram and configurations of all devices, upload them as separate files for conviniency, please.
