Trunk won't stay live
cmorris12
I have an odd event happening. I have two chassis that I am trying to trunk together.
The first chassis is a 6509 with a S720-10G sup module. The second chassis is a 6504 with a Sup32-10GE-3B sup.
I am using an X2-LR in the S720-10G slot 1 and an Xenpack-LR in the Sup32-10GE-3B slot 1.
I can bring the trunk up and it runs fine for a while. Then at random times, it just drops. There is nothing in the log files to tell me what is happening. The only thing there is the adjecency notices. I have tried everything I know:
Changed the patch cables
Change the GBICS
Tried every configuration (auto, on, desirable, etc).
I can not get this stupid trunk to stay live.
I do get some crc errors on the trunk and a couple giants as the link comes up .. but, that is about it...
The only other piece to this is I have 50 micron fiber between them.
When I read the docs on the transcievers, I  think the issue may be the 50 micron fiber. But, I also wonder if the xenpack and the x2 are truly compatiable.
Has anyone had this scenario or suggestions on how to move forward to make this work?
Jerry Ye
In your original message, you said it is a 50 micron fiber and the optic is X2-10GB-LR and XENPAK-10GB-LR? I just want to make sure you are not using the LRM optic. If that is true, then the fiber is MMF and the spec for the X2-10GB-LR and XENPAK-10GB-LR require SMF
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5138/product_data_sheet09186a008007cd00_ps5251_Products_Data_Sheet.html
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6574/product_data_sheet0900aecd801f92aa.html
HTH,
jerry
Jerry Ye
HTH,
jerry
No, I am NOT using LRM. But, it does bring up an interesting point ...
the LR uses G.652 and I am using 50 micron ..the window is simply too small to stay live for long periods or when a lot of data is flowing ... so, technically if I switch over to the X2-SR and Xenpack-SR it should align back up ...
There are some days I just overlook the obvious ..
I think you just answered it .. sometimes we get too close to an issue and don't take a fresh look. Going to go try it this afternoon.
Please excuse my previous stupid question.
You got that right, SR should be able to do it if it is within the distance. BTW G.652 is really the spec for SMF (Single Mode Fiber), and the core size is less than 10 micron.
jerry
just changes gbics and everything is fine now ...
I simply got in too big a hurry ... too little help and too much to do ..
Thanks for the sanity check.
